Hello all! I'm new to the forum, but so far I can tell there's loads of very helpful info on here!
Well to start, I just got my Davis VP2 with 24 Hour FARS for Christmas. I love it so far!
My set up is WeatherLink IP through a WiFi bridge to Cumulus. I did this because I wanted my console separate from the computer and router. The ISS and anemometer are on a tripod in my backyard. There's a picture of the station on the "About this PWS" on my Wunderground page here:
http://www.wunderground.com/personal-weather-station/dashboard?ID=KALHUNTS54#history.
So now to my problem... I believe my fan is running backwards. It is blowing air out of the bottom of the unit and not sucking in like the diagram in the manual suggests. I think this may be what is causing the little spikes on the temp graph during the day. I'm guessing that the sun is heating up the plates and as air crosses the plates as it's sucked in at the top, it is heated slightly. Has anyone ever had this problem? I saw a thread where someone installed a new board and the fan spun backwards, but not straight out of the box brand new... I emailed Davis, but I don't expect to hear back from them until Monday.
Also, I'm not so sure the fan is spinning at night either. During the day when the sun shines right on the solar panel, it makes an audible whirring and slight knocking noise. When I cover the panel, it abruptly slows down and there's hardly any air blowing out of the bottom. The same is true at night. There is absolutely no noise even with my ear touching the unit and no noticeable air coming out of the bottom. I've taken a piece of plastic wrap to test it out; during the day it easily pushes the plastic away from the vent but at night, nothing.
So I guess my questions are: is there an easy fix to reversing the fan direction? Is it a bad board? Are the batteries installed backwards? Are the batteries loose? Would removing the batteries and charging them help them last longer into the night?
Thanks for the help in advance!
Alex
