Weather Software => GRLevel X Software => Topic started by: mkutche on August 16, 2014, 07:13:43 PM
I'm still new at GR3 and all of the sites you guys listed don't exist from what I've seen.. I'm looking for DBZ color tables for both rain/snow .. and how do you change backgrounds in GR3?
Mike
Hi Mike,
Attached are the color tables I use with GR3 ver. 2. The background within ver. 2 cannot be changed. You have to use either the NAIP maps or use a solid color background, unless someone has figured a way around this.
Hi Mike,
thanks john and no i haven't found a way around the background thing it's driving me bonkers haha. i use GR3 V2 as well forgot to mention that :P
Mike
Hello guys, i would like to chime in here. First of there is no snow DBZ or not that im aware of as Grlevelx does not support winter weather radar. But if you go into HCA and look on the left hand side you will see WS or IC thas for Wet snow and ICE, As for putting a new back round in Grlevelx that is not possable in the new version 2.17 as in the old version you could. And if im correct you are talking about The display and how it looks. I also know that you can not change the color tables or everything as in Base Rell and storm rell and so on wich u used to. Now i could be wrong on this as i do have color tables that i used to use wich i wana use again but i havent found a way to put them in so. Hope this helpes,Also if some one knows a way to put color tables in please help me. Good god
my bad wow, i just figued this out. go into Veiw and then goto color tables settings and then choose or click the table you wana change and then to the right place the updaed color table in there. But i would love to see more Color tables as i miss them and ever since Grlevelxstuff went ofline i cant find any no more. So please share. Thanks
Here are the ones I'm using, some copied, some created. The one for base reflectivity does a good job showing none precipitation (outflow boundaries, etc.) in shades of grey and slate, and the other colors seem to do a better job indicating the actual intensity.
Base Reflectivity: fade_reflectivity(2).pal
Base Velocity: Pueblo_BV.pal
Storm Relative Velocity: Pueblo_SRV.pal
Echo Tops: new_echotops.pal
Duh, ".pal" files are not permitted...the ".txt" equivalent is attached. ](*,)
My main radar page: http://www.lfweathercenter.com/fullradar.php
...and since we have a 4 attachment limit...here are VIL, One Hour Precip & Storm Total Precip.
Does any one Have any Storm Relictivity velocity color tables along with BV and BR color tables ? would love to see some. Thanks :)
Maybe we could change the title of this thread to just 'Color Tables' (?) I have a bunch of GR2, GR3, and GREarth color tables, I'd be happy to add on here. :-)
Please Post those color tables for Grlevelx 2.0 as im looking for some for Storm Relectivity Bace Rel and so on- Post them up gang. Im dying for some Thanks
I'll have some up for you by tonight! 8-)
Here is a GR3 2.0 base reflectivity table I created a few weeks ago with a screenshot of it in action:
Product: BR
Units: DBZ
Step: 5
Color: 15 17 17 255 0 0 179
Color: 18 0 255 0 0 236 0
Color: 20 0 206 0 0 169 0
Color: 25 0 128 0 0 108 0
Color: 30 0 79 0 0 61 0
Color: 35 255 255 0 230 230 0
Color: 40 225 192 4 193 165 4
Color: 45 255 128 0 198 99 0
Color: 50 255 0 0 220 0 0
Color: 55 168 0 0 103 0 0
Color: 60 255 0 255 196 0 196
Color: 65 128 0 128 64 0 64
Color: 70 255 255 255 128 128 128
Color: 75 128 128 128 0 0 0
Here is a slightly different variant of the reflectivity I posted earlier. I'll begin posting velocity pictures tomorrow (Gotta order some velocity data from the NCDC to show it in action). I don't use this one quite as much as the other one but still enjoy it.
Product: BR
Units: DBZ
Step: 5
Color: 15 162 162 255 0 0 255
Color: 18 0 255 0 0 237 0
Color: 20 0 211 0 0 188 0
Color: 25 0 160 0 0 128 0
Color: 30 0 104 0 0 73 0
Color: 35 255 255 0 217 217 0
Color: 40 255 128 0 222 111 0
Color: 45 192 96 0 128 64 0
Color: 50 255 0 0 213 0 0
Color: 55 170 0 0 128 0 0
Color: 60 255 0 255 211 0 211
Color: 65 156 0 156 128 0 128
Just ran across two examples of the BR & BV color tables I shared above.
Hola everyone 8-) Been a little silent over here, as I've been working on my dissertation for school, but I have recently created a couple of color tables that I figured I could share. These are all for GREarth, but eventually I will create some for GR3 :-) Enjoy!
Image 1: Contours 2 Meter Temperature
LineForeground: 2 255 255 255 ;
Value: -30
LineForeground: 2 210 210 210 ;
Value: -25
LineForeground: 2 170 170 170 ;
Value: -20
LineForeground: 2 128 128 128 ;
Value: -15
LineForeground: 2 80 80 80 ;
Value: -10
LineForeground: 2 40 40 40 ;
Value: -5
LineForeground: 2 0 0 0 ;
Value: 0
LineForeground: 2 64 0 64 ;
Value: 5
LineForeground: 2 128 0 128 ;
Value: 10
LineForeground: 2 192 0 192 ;
Value: 15
LineForeground: 2 255 0 255 ;
Value: 20
LineForeground: 2 0 149 149 ;
Value: 25
LineForeground: 2 0 93 93 ;
Value: 30
LineForeground: 2 0 0 255 ;
Value: 32
LineForeground: 2 0 0 64 ;
Value: 35
LineForeground: 2 0 64 0 ;
Value: 40
LineForeground: 2 0 128 0 ;
Value: 45
LineForeground: 2 0 192 0 ;
Value: 50
LineForeground: 2 0 255 0 ;
Value: 55
LineForeground: 2 255 255 0 ;
Value: 60
LineForeground: 2 185 185 0 ;
Value: 65
LineForeground: 2 255 128 0 ;
Value: 70
LineForeground: 2 155 78 0 ;
Value: 75
LineForeground: 2 255 0 0 ;
Value: 80
LineForeground: 2 128 0 0 ;
Value: 85
Value: 90
Value: 95
Value: 100
LineForeground: 2 192 192 192 ;
Value: 105
Value: 110
LineForeground: 2 64 64 64 ;
Value: 115
Value: 120
Image 2: MSLP
LineForeground: 2 0 0 202 ;
Value: 1030
Value: 1025
LineForeground: 2 0 128 255 ;
Value: 1020
LineForeground: 2 100 100 100 ;
Value: 1015
LineForeground: 2 150 150 150 ;
Value: 1010
Value: 1005
LineForeground: 2 255 128 128 ;
Value: 1000
LineForeground: 2 255 75 75;
Value: 995
Value: 990
LineForeground: 2 210 0 0 ;
Value: 985
LineForeground: 2 168 0 0 ;
Value: 980
Value: 975
Value: 970
LineForeground: 2 170 0 170 ;
Value: 965
LineForeground: 2 215 0 215 ;
Value: 960
Value: 955
LineForeground: 2 255 128 255 ;
Value: 950
LineForeground: 2 255 192 255 ;
Value: 945
Value: 940
And here's three color fills 8-)
Image 1: Color Fill 2 Meter Temperature
; Default 2 meter temperature color table
; Internal units are °C so we convert to °F
; with Scale: and Offset:
Product: 2MT
Units: °F
Step: 5
Scale: 1.8
Offset: 32
SolidColor: -30 0 0 0
SolidColor: -25 50 50 50
SolidColor: -20 100 100 100
SolidColor: -15 150 150 150
SolidColor: -10 200 200 200
SolidColor: -5 255 255 255
SolidColor: 0 64 0 64
SolidColor: 5 128 0 128
SolidColor: 10 184 0 184
SolidColor: 15 255 0 255
SolidColor: 20 0 255 255
SolidColor: 25 0 204 204
SolidColor: 30 0 128 255
SolidColor: 32 0 0 255
SolidColor: 35 0 0 160
SolidColor: 40 0 128 0
SolidColor: 45 0 170 0
SolidColor: 50 0 210 0
SolidColor: 55 0 255 0
SolidColor: 60 255 255 0
SolidColor: 65 217 217 0
SolidColor: 70 255 128 0
SolidColor: 75 200 100 0
SolidColor: 80 255 0 0
SolidColor: 85 170 0 0
SolidColor: 90 150 0 150
SolidColor: 95 210 0 210
SolidColor: 100 255 255 255
SolidColor: 105 200 200 200
SolidColor: 110 150 150 150
SolidColor: 115 100 100 100
SolidColor: 120 50 50 50
SolidColor: 125 0 0 0
Image 2: Color Fill 2 Meter Dew Point
; Default 2 meter dewpoint color table
Product: 2MD
Units: °F
Step: 5
Scale: 1.8
Offset: 32
SolidColor: 40 0 0 0
SolidColor: 45 227 210 157
SolidColor: 50 210 182 96
SolidColor: 60 0 215 0
SolidColor: 65 0 175 0
SolidColor: 70 0 128 0
SolidColor: 75 250 159 99
SolidColor: 80 248 119 33
Image 3: CAPE
Product: CAPE
Units: J/kg
Step: 500
Solidcolor: 500 0 0 255
Solidcolor: 1000 0 255 0
Solidcolor: 1500 0 128 0
Solidcolor: 2000 255 255 0
Solidcolor: 2500 255 128 0
Solidcolor: 3000 255 0 0
Solidcolor: 3500 128 0 0
Solidcolor: 4000 128 0 128
Solidcolor: 4500 255 0 255
Solidcolor: 5000 255 255 255
Solidcolor: 5500 128 128 128
Solidcolor: 6000 0 0 0
Hello Gang I have had my grlevelx for a very long time now and love it and the community is great as well those who make color tables. I have Another Request. I cant seem to find a BR Color Table that will pick up the rain good at all. Meaning it will show rain in other parts of the state and when I look out side its Raining. So im gunna need to delete some of these color tables and add new ones. What im asking is can any one make a HD Smooth and shows every were where its Raining as this is important to me as what good is the color table if it dosent depict all the rain. again I need a BR HD smooth Quality . Any one
