Author Topic: For Sale - Davis Green dot compatible Data Loggers & Raspberry Pi2  (Read 21213 times)
Offline Uksa007
  • Need a Logger board?
Re: For Sale - Davis Green dot compatible Data Loggers & Raspberry Pi2
« Reply #25 on: October 22, 2015, 01:46:00 AM »
That would work for me. If Belfryboy doesn't answer my PM soon I'll order one from you.
Thank you.
TLW
Sure, let me know I have one RS232 in stock.
Regards.
Need a green dot compatible Data Logger Board for your Davis VP, VP2, Vue or Weather Envoy?
USB Version uses genuine FTDI USB chip, includes 2m USB Cable $79.99 USD order here
RS232 Version uses genuine MAX3221E chip, includes 1.5m DB9 Cable  $89.99 USD order here
See here for more info.
Offline noamik
« Reply #26 on: November 21, 2015, 04:44:13 PM »
I received mine (USB version) today and it's working like a charm. I like the clean soldering on the PCB. Thanks a lot for your work ...
Offline Uksa007
« Reply #27 on: December 17, 2015, 01:05:37 AM »
Thanks for the Positive feed back.
I have a built up a few USB loggers for Christmas stock, figure they would make good Xmas presents to go with weather stations some lucky people might be getting for Christmas.
With Christmas coming most suppliers will be closing down, so get them before they are gone!
See the first post in this thread for detail and how to order.
« Last Edit: December 17, 2015, 02:24:14 AM by Uksa007 »
Offline WXWIZARD
« Reply #28 on: December 17, 2015, 01:29:04 PM »
Does the price include shipping?
Offline Uksa007
« Reply #29 on: December 17, 2015, 04:30:02 PM »
Prices include free international shipping without tracking, tracking options are available please see the first post of this thread for further details.
Regards.
Offline jparmelee
« Reply #30 on: January 12, 2016, 11:13:00 AM »
Just got my USB logger yesterday.  Got here in about 10 days.  No issues and it works great.  Thanks Uksa007!
@justinparmelee | Westwood, Massachusetts |  Davis Vantage Vue + USB logger + Raspberry Pi + WeeWX | KMAWESTW11
Offline ppmax
« Reply #31 on: January 25, 2016, 11:46:07 PM »
Hi--
I got my logger the other day and just tried getting everything working on my RPi tonight. It looks like the connection to the console is working...I can do a wee_device --info and see that it's communicating with the Davis...but checking my syslog I get this:
Jan 25 21:44:11 rasp weewx[3707]: engine: Starting main packet loop.
Jan 25 21:44:17 rasp weewx[3707]: vantage: LOOP #1; read error. Try #1
Jan 25 21:44:17 rasp weewx[3707]:    ****  Expected to read 99 chars; got 0 instead
Jan 25 21:44:22 rasp weewx[3707]: vantage: LOOP #2; read error. Try #2
Jan 25 21:44:22 rasp weewx[3707]:    ****  Expected to read 99 chars; got 0 instead
Jan 25 21:44:27 rasp weewx[3707]: vantage: LOOP #3; read error. Try #3
Jan 25 21:44:27 rasp weewx[3707]:    ****  Expected to read 99 chars; got 0 instead
Jan 25 21:44:32 rasp weewx[3707]: vantage: LOOP #4; read error. Try #4
Jan 25 21:44:32 rasp weewx[3707]:    ****  Expected to read 99 chars; got 0 instead
Jan 25 21:44:32 rasp weewx[3707]: vantage: Max retries (4) exceeded.
Jan 25 21:44:32 rasp weewx[3707]: engine: Caught WeeWxIOError: Max retries exceeded while getting LOOP data.
Jan 25 21:44:32 rasp weewx[3707]:     ****  Waiting 60 seconds then retrying...
Any suggestions?
thx
PP
Offline Uksa007
« Reply #32 on: January 26, 2016, 05:30:51 AM »
Hi--
Any suggestions?
thx
PP
I don't use weewx, so can't offer any help with it, I use Cumulus MX on my raspberry pi.
There is some suggestion there are issues with the current version of weewx and the loop command, see here https://groups.google.com/forum/m/#!topic/weewx-user/PJK8Hr5Xip0
I would suggest that you start with confirming you are able to send and receive data from the logger.
SSH into the raspberry pi and install some terminal software and connect to the logger.
Set the baud rate to 19200 8N1 and send TEST
It should respond with TEST
Send NVER
It should respond with the version of the console firmware.
If it's not responding check the port and driver is loading, using dmesg
Once you have confirmed the logger is communicating, you can continue your trouble shooting with weewx, or install cumulus mx, it just works.
Offline ppmax
« Reply #33 on: January 27, 2016, 12:21:00 AM »
Thanks Uksa007--
I think I got it all squared away now...it's up and running and logging.
PP
Offline Uksa007
« Reply #34 on: January 27, 2016, 01:04:51 AM »
Thanks Uksa007--
PP
What was the issue, in case someone else encounters similar issues with weewx?
Offline ppmax
« Reply #35 on: January 27, 2016, 08:56:45 PM »
Good idea:
I don't think it was weewx per se...i think when you first connect and turn the machine on you need to let it do it's thing. I was configuring weewx, restarting the weewx service, testing the connection, etc...and I think testing the communication with the console interrupts the modem.
Anyways, it seems like it's been all good for a couple days now.
PP
Offline hurring
    • Inverleigh Weather
« Reply #36 on: February 15, 2016, 03:14:53 AM »
My logger arrived nice and quickly. Lovely work and well put together. I have connected it to my vantage Vue and it is working nicely.
Cheers
Adrian
Offline Uksa007
« Reply #37 on: May 12, 2016, 09:04:01 PM »
I have couple more of USB Logger in stock ready to ship, get them before they are gone.
Regards,
Uksa007
Offline Brientim
« Reply #38 on: May 28, 2016, 05:24:29 PM »
Hello,
I assume usb are still available and by postage, your in AUS?
Offline Uksa007
« Reply #39 on: May 28, 2016, 08:35:34 PM »
Hello,
Yes I still have a few USB loggers in stock ready to ship.
Regards.
Offline Brientim
« Reply #40 on: May 28, 2016, 09:41:14 PM »
Ordered
Offline bru
« Reply #41 on: June 01, 2016, 02:47:06 PM »
Ordered
Offline smilingreen
« Reply #42 on: July 03, 2016, 04:35:24 PM »
Ordered
Offline Uksa007
« Reply #43 on: July 06, 2016, 03:11:23 AM »
I have a few RS232 and USB loggers in stock.
Next batch there will be a price rise due to increased cost of components and PayPal fees.
Get them before they are gone and beat the price rise!
Regards
Offline Uksa007
« Reply #44 on: September 03, 2016, 09:10:52 PM »
I've been getting a lot of PM asking if I still stock loggers.
Yes I have them in stock and ready to send!
Regards.
Offline Uksa007
« Reply #45 on: November 17, 2016, 06:18:08 PM »
I have USB and RS232 loggers in stock Ready to ship, order now to receive before Christmas!!
Offline bru
« Reply #46 on: November 18, 2016, 03:54:41 AM »
Could you reply to the message I sent you in October?
thanks
Offline Uksa007
« Reply #47 on: November 18, 2016, 05:46:54 AM »
thanks
Sorry missed your message, I have responded now, and for anyone else that may be wondering what the capacity of the logger is:
Archive Storage Capacity (the amount of time before the archive is completely filled):
1 Minute Archive Interval . . . . . . . . . . . . . . . . . . . . . 42 hours
5 Minute Archive Interval . . . . . . . . . . . . . . . . . . . . . 8 days
10 Minute Archive Interval . . . . . . . . . . . . . . . . . . . . 17 days
15 Minute Archive Interval . . . . . . . . . . . . . . . . . . . . 26 days
30 Minute Archive Interval . . . . . . . . . . . . . . . . . . . . 53 days
60 Minute Archive Interval . . . . . . . . . . . . . . . . . . . . 106 days
120 Minute Archive Interval . . . . . . . . . . . . . . . . . . . 213 days
Offline bru
« Reply #48 on: November 18, 2016, 07:21:11 AM »
thanks a lot!!   :grin:
Offline Uksa007
« Reply #49 on: January 11, 2017, 07:10:05 PM »
Loggers in stock and ready to ship same day!
