I have a new 01301CCDI I just got, and I've noticed the barometer reads a fair bit lower then actual pressure.
At this moment, actual is 29.9 (Environment Canada/local airport) while the 01301 shows 29.34
My old Springfield agrees with the airport (mainly because it's adjusted that way) I should mention I'm in a 8th floor apartment on a bit of a hill.
Will the learning mode correct this in time, or should I be doing the manual calibration on it to match it to actual pressure? Sorry if this is a dum question, but I'm totally new to having a electronics weather station.
I'm also see it showing 99% humidity right now, even though the airport is 100%, and HEAVY fog right now, I literally can hardly see the building across the driveway right now. is that normal?
thanks
