Author Topic: "Map is not current. Data from Blitzortung is not available."  (Read 5778 times)
Offline gwwilk
  • Southeast Lincoln Weather
Ken's NA and US past 2 hour strikes maps aren't getting any data for some reason.  I also use these scripts and have the same problem.
I'm curious as to what's going on with this!
Regards, Jerry Wilkins
gwwilk@gmail.com
Re: "Map is not current. Data from Blitzortung is not available."
« Reply #1 on: July 16, 2018, 08:11:15 AM »
See this thread: https://www.wxforum.net/index.php?topic=31584.0
The upshot is that the data source was moved from lightningmaps.org to blitzortung.org.
Offline gwwilk
« Reply #2 on: July 16, 2018, 08:25:52 AM »
Thanks, Greg, but the relevant configuration in 'BO-mapgen.inc' is already set to
$mainURL = 'data.blitzortung.org';
and it's still not receiving data.
There has been a server IP change recently, and I wonder if it hasn't propagated through the DNS servers yet.
gwwilk@gmail.com
« Reply #3 on: July 16, 2018, 08:26:16 AM »
Is this the actual animate.txt file that you are using? This seems to be the default and HDIR is not pointing to your own server directory... (assuming that you are not "kunden")
#!/bin/bash
# generic bash script for gen-BO-maps.php.  K. True - saratoga-weather.org
# Version 1.00 - 18-Apr-2015 - initial release
# --- begin settings
# set HDIR to full file path to BOmaps directory on your website
HDIR=/kunden/homepages/9/d141952417/htdocs/wx/BOmaps
# set PHPcmd to full path to PHP V5+ on your host
PHPcmd=/usr/bin/php
# --- end settings
cd $HDIR
$PHPcmd -q gen-BO-maps.php > status.txt 2>&1
Maybe your animate.txt got overwritten during an update?
« Reply #4 on: July 16, 2018, 08:28:33 AM »
Hmmm... Mine shows no strikes either...
Offline gwwilk
« Reply #5 on: July 16, 2018, 08:32:38 AM »
Frustrating problem this morning, eh?
gwwilk@gmail.com
« Reply #6 on: July 16, 2018, 08:39:12 AM »
My status page is showing 0 B is strikes.txt file size used by Blitzortung.
Offline gwwilk
« Reply #7 on: July 16, 2018, 08:40:57 AM »
I suspect that server changes, possibly including a modified data format, are responsible for our current difficulties.
In trying to reference specific posts on the forum I came up with no way to do so.  There are references to a changed IP address as well as a new data format, but they have to be chased down rather than linked to.  Why don't they allow links individual posts?
gwwilk@gmail.com
« Reply #8 on: July 16, 2018, 08:41:40 AM »
https://dnschecker.org/#A/data.blitzortung.org reports all green check marks, so DNS is OK.
« Reply #9 on: July 16, 2018, 09:00:02 AM »
My http://miraculon.net/BOmaps/cache/gen-BO-maps-log.txt is reporting a bunch of [0] => HTTP/1.1 401 Unauthorized errors.
p.s. I tried entering the http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2018/07/16/11/10.json.gz directly into the browser URL bar and I get apparent login failures with that.
(yes, I did change the user:pass-omitted to the correct entries)
« Last Edit: July 16, 2018, 09:24:20 AM by miraculon »
Online PaulMy
« Reply #10 on: July 16, 2018, 09:18:23 AM »
Hi Greg,
Mine shows similar but notice a newer version http://www.komokaweather.com/BOmaps/cache/gen-BO-maps-log.txt
I notice mine is:
BOmapgen - V1.04 - 29-Sep-2017
and yours:
BOmapgen - V1.00 - 18-Apr-2015
« Reply #11 on: July 16, 2018, 09:22:38 AM »
I suggest changing to data2.blitzortung.org from data.blitzortung.org for the lightning data .. the data server seems to be overloaded at this time.
Offline gwwilk
« Reply #12 on: July 16, 2018, 09:47:13 AM »
Thanks, Ken!  I see you have data available again, so I just made the change you suggested.
gwwilk@gmail.com
« Reply #13 on: July 16, 2018, 10:07:37 AM »
Thanks, Ken. That seems to be loading again.
Offline fpalafox
    • Hermosillo Weather
« Reply #14 on: December 22, 2018, 08:59:45 PM »
Hello, I start having issues with lightning update in my web page. I am using a Saratoga scripts to include lightning in climason.com but now not strikes are included. I validate my user/ password and is ok from my blitzortung account. I check my local log and not strikes are downloaded. DO you know if servers or configurations are changed? I try using data.blitzortung.org or data2.blitzortung.org servers and still same issued.
Thank you in advance.
Wunderground: ISONORAH5
CWOP: CW2548
AWEKAS: 7184
Blitzortung: 1023 Hermosillo,Mex
www.climason.com
« Reply #15 on: December 22, 2018, 10:16:13 PM »
Blitzortung has changed the structure of the stations file .. you need the updated V1.05 of the maps.  I've sent the link via PM.
The updates are to BO-mapgen-inc.php and BO-station-inc.php to support the revised stations file format.
Offline fpalafox
« Reply #16 on: December 29, 2018, 03:13:51 PM »
Thank you very much for your help. Now blitzortung scripts are working fine.
Have a happy new year!!
CWOP: CW2548
AWEKAS: 7184
www.climason.com
Offline fpalafox
« Reply #17 on: February 15, 2019, 04:39:50 PM »
After I upgrade to Ver 1.05 (Thanks Ken), all was working fine. But now maps is not current, message is displayed. I reinstall again the script, i review user/password and I start the manually update (http://climason.com/BOmaps/gen-BO-maps.php) but still same issue. Any ideas?
this Happend when I start manually:
BOmapgen - V1.05 - 30-Oct-2018 BO MOTD: 'Blitzortung.org message: Network for Lightning and Thunderstorms in Real Time' BO MOTD written to cache/BOmotd.txt with 94 bytes. Parms: URLPath='/BOmaps/' for map gen Parms: maxFilesize='200 MB' for cache/strikes.txt Parms: ourTZ='America/Hermosillo' Running PHP 5.6.38 start processing for region 3 data Fri, 15 Feb 2019 14:37:43 current cache/strikes.txt strikes file size is 0 B cache/strikes.txt filtered for old data First data: Wed, 31 Dec 1969 16:00:00 Last data : Fri, 15 Feb 2019 12:37:43 old data - restart collection from Fri, 15 Feb 2019 12:37:43 fetching new strikes file at http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/30.json
Warning: get_headers(http://...@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/30.json): failed to open stream: operation failed in /home/climaso1/domains/climason.com/public_html/BOmaps/BOmapgen-inc.php on line 196
Headers returned from http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/30.json fetching new GZ strikes file at http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/30.json.gz
Warning: get_headers(http://...@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/30.json.gz): failed to open stream: operation failed in /home/climaso1/domains/climason.com/public_html/BOmaps/BOmapgen-inc.php on line 235
Headers returned from http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/30.json.gz fetching new strikes file at http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/40.json
Warning: get_headers(http://...@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/40.json): failed to open stream: operation failed in /home/climaso1/domains/climason.com/public_html/BOmaps/BOmapgen-inc.php on line 196
Headers returned from http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/40.json fetching new GZ strikes file at http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/40.json.gz
Warning: get_headers(http://...@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/15/19/40.json.gz): failed to open stream: operation failed in /home/climaso1/domains/climason.com/public_html/BOmaps/BOmapgen-inc.php on line 235
CWOP: CW2548
AWEKAS: 7184
www.climason.com
« Reply #18 on: February 15, 2019, 10:36:42 PM »
Since no header info is actually returned, I suspect that your website can't connect to data.blitzortung.org server.  This can be caused by either a DNS issue, or by a routing issue (your webserver to data.blitzortung.org at 88.99.64.19 )
It's something for the tech support for your hoster to check out.  Ask them to SSH to the server and do a nslookup and ping for data.blitzortung.org to further diagnose the problem.
My site is not having issues with access to data.blitzortung.org currently so maps are current.
Offline fpalafox
« Reply #19 on: February 18, 2019, 11:07:28 AM »
Thank you Ken.
I am trying to contact to my web support. By the way, I created a host.php same directory where BOmaps are located (http://www.climason.com/BOmaps/host.php). THis happend when i try to locate data.blitzortung.org:
data.blitzortung.org resolved to 88.99.64.19
Whois (IP) Results:
sh: whois: command not found
Whois (Domain) Results:
NS Lookup Results:
Server:   67.207.67.3
Address:   67.207.67.3#53
Non-authoritative answer:
Address: 88.99.64.19
Ping Results:
PING data.blitzortung.org (88.99.64.19) 56(84) bytes of data.
64 bytes from static.19.64.99.88.clients.your-server.de (88.99.64.19): icmp_seq=1 ttl=51 time=162 ms
64 bytes from static.19.64.99.88.clients.your-server.de (88.99.64.19): icmp_seq=2 ttl=51 time=161 ms
64 bytes from static.19.64.99.88.clients.your-server.de (88.99.64.19): icmp_seq=3 ttl=51 time=161 ms
64 bytes from static.19.64.99.88.clients.your-server.de (88.99.64.19): icmp_seq=4 ttl=51 time=161 ms
--- data.blitzortung.org ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 161.145/161.451/162.269/0.551 ms
Traceroute Results:
sh: traceroute: command not found
Tracepath Results:
1?: [LOCALHOST] pmtu 1500
1: XSDA19006.XPRESS.COM.MX 6.823ms reached
1: XSDA19006.XPRESS.COM.MX 7.074ms reached
Resume: pmtu 1500 hops 1 back 1
CWOP: CW2548
AWEKAS: 7184
www.climason.com
« Reply #20 on: February 18, 2019, 11:16:13 AM »
So it looks like DNS is resolving successfully and you can PING to that host.
Try changing lines in BOmapgen-inc.php
$T_begin = microtime(true);
    $lines = @file($filename,0,$context);
to
    $lines = file($filename,0,$context);
so you can see the PHP error messages about the connection.
Offline fpalafox
« Reply #21 on: February 19, 2019, 11:01:00 AM »
I removed @.
File included.
CWOP: CW2548
AWEKAS: 7184
www.climason.com
« Reply #22 on: February 19, 2019, 11:32:00 AM »
Well, that was largely unhelpful .. the error messages like
Warning: file(http://...@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/19/13/50.json): failed to open stream: operation failed in /home/climaso1/domains/climason.com/public_html/BOmaps/BOmapgen-inc.php on line 195
don't provide any additional info to point to what might be failing.  Grrrr...
Are you sure that your Blitzortung $region $username and $password are set correctly in gen-BO-maps.php?  Since you are able to access the main site as shown by
it appears that data.blitzortung.org is maybe refusing the connection due to improper credentials.
I'd revert the code to put the @ back also.
Offline fpalafox
« Reply #23 on: February 19, 2019, 06:39:38 PM »
I copy credentials from gen-BO-maps and paste to http://en.blitzortung.org/user_data.php?session=1. Work fine!!!
I try access from my pc to blitzortung server
http://data.blitzortung.org/Data_3/Protected/Strikes/2019/02/19/21/10.json.gz
 If I check, I dont see any .json.gz file, only  .json files are displayed. I dont know if it is a issue or not.
There are references to json.gz files.
Warning: get_headers(http://...@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/19/21/20.json): failed to open stream: operation failed in /home/climaso1/domains/climason.com/public_html/BOmaps/BOmapgen-inc.php on line 196
Headers returned from http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/19/21/20.json fetching new GZ strikes file at http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/19/21/20.json.gz
Warning: get_headers(http://...@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/19/21/20.json.gz): failed to open stream: operation failed in /home/climaso1/domains/climason.com/public_html/BOmaps/BOmapgen-inc.php on line 235
Headers returned from http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/19/21/20.json.gz fetching new strikes file at http://user:pass-omitted@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/19/21/30.json
Warning: file(http://...@data.blitzortung.org/Data_3/Protected/Strikes/2019/02/19/21/30.json): failed to open stream: operation failed in /home/climaso1/domains/climason.com/public_html/BOmaps/BOmapgen-inc.php on line 195
CWOP: CW2548
AWEKAS: 7184
www.climason.com
« Reply #24 on: February 20, 2019, 10:45:40 AM »
The nn.json files are available on data.blitzortung.org initially as uncompressed, then after a time, they are automatically gzipped by the Blitzortung server to conserve space.  The script always trys the nn.json file first, and if it fails, tries the nn.json.gz file for the data.
I trust that your userid and password for Blitzortung do not contain the characters '@' or ':' in them.. If those characters are in either, the GET-mode URL will fail due to invalid syntax (as the colon separates the userid from the password, and the @ separates the user:pass from the hostname).
