Some scripts are weather station software dependent and only work with that software - example is the Alternative Dashboard which is Weather-Display specific. There are some summary scripts that rely on NOAA climate reports, so only the software that generates those (Weather-Display, Cumulus, VWS, WeatherLink) can use those scripts. Other scripts are agnostic about the weather software as they use external sources of data.
It would be helpful to understand which scripts you're looking at, then a more definitive answer about "does it work with meteobridge" could be done.
