give davis an email to their support dept. According to their replacement parts, the foam plug isn't offered. I do have issues with that opening.
First the plug is a bad idea .. however...
IF you run in the rain, solar, uv, temp, wind and FARS, it gets really crowded an a pain to work with. When I installed the daytime FARS, the motor was bad and had to be replaced three times. It was a royal pain in the rear to pull out and put in the FARS lead with all the other things that go in that small port opening, then push the foam back in... a poor design.
I am sure the foam must degrade in time from the temperature build up on one side and the elements on the other ( the usual plus pollution).
I also have a soil test station and I noted that the thin gasket around the door tends to come out of the grooves and needs to be periodically pushed back in.
Last, on that particular station, if you are using 4 soil moisture leads (each are 2 strand) and 4 temperature leads , then include at least one leaf wetness sensor lead, it makes a very crowded entry port through the grommet and allows a gap for critters.
On several occasions I have found bugs in the sensor box. Now if those critters can get in, so can moisture. That as well needs to be improved.
Suggestions?
