Author Topic: Ecowitt hp2551, ambient Weather ws-2000, fine offset hp2550 and Weewx  (Read 2085 times)
Offline superdevil669
    • MétéWapi
Hello everyone, I just purchased an Ecowitt hp2551 station that is similar to the thin offset hp2550 and ambient Weather ws-2000.
The USB port does not seem to be able to broadcast data.
So I'm looking at how to allow Weewx to recover the data.
Could you tell me how to do it step by step?
Weewx and install on a 1st generation Raspberry.
My station and connect to wifi under the address 192.168.1.35.
I tried to put the interceptor drivers in Weewx but no run data.
Thank you in advance
You need to create a separate WiFi hotspot on the Raspberry Pi. The weather console then needs to connect to this other WiFi SSID that is not the same as your home WiFi. Then the Interceptor driver will see the data being sent to WU.
Offline droiddk
Documentation for the interceptor driver is here:
https://github.com/matthewwall/weewx-interceptor/blob/master/readme
Maybe there is a new easier way getting the data to Weewx (still using the interceptor driver): Can the hp2551 console do "customized upload"? If yes then maybe the Wunderground data (called "Wunderground procotol") can be send directly to the interceptor driver, without using a Firewall-on-Router, Bridge, Tap-on-Router, Tap-on-Hub, Tap-on-Switch or Tap-on-wireless. Example 1 in documentation.
Regards
    • MétéWapi
Thanks for the information.
My hp2551 actually has an option in the ws view application that allows a customized upload with Ecowitt or wunderground protocol.
This one asks me for an IP Server / Hostname
ID station
Station Key Key
Port
Upload interval
Unfortunately as I don't speak English well ( I use a translator to write and understand the forum)
I don't understand how to send everything on my raspberry and how to do it with interceptor
thank you
Translated with www.DeepL.com/Translator
Offline droiddk
ID station
Station Key Key
Port
Upload interval
thank you
Ok. Then, why do you want to use WeeWx? Maybe easier alternatives exists. http://www.ecowitt.net is pretty good! Also your console supports direct upload to WU and Weathercloud.
Regards
    • MétéWapi
Indeed, what the base station offers is very good.
I want to use weewx to send the data to my weather site ( https://meteowapi.be) which basically uses the data from the station I put at my parents' and uses weewx in usb.
So I would like to add the data according to the templates I made so that everything is homogeneous
Offline droiddk
Ok. Its a long shot, I have not tried it myself but try:
In WS View, "Customized" try:
Server IP / Hostname: Hostname of your PI, not sure IP works.
Station ID: Anything you like, you don't upload to WU.
Station Key: Anything you like, you don't upload to WU.
Port: 80
Upload Interval: 16
And do this:
Installation
0) install weewx, select 'Simulator' driver
http://weewx.com/docs/usersguide.htm#installing
1) download the interceptor driver
wget -O weewx-interceptor.zip https://github.com/matthewwall/weewx-interceptor/archive/master.zip
2) install the driver
sudo wee_extension --install weewx-interceptor.zip
3) configure the driver
sudo wee_config --reconfigure --driver=user.interceptor --no-prompt
4) start weewx
sudo /etc/init.d/weewx start
    • MétéWapi
agree and at the level of the file weewx.conf
I have to put
[Interceptor]
    driver = user.interceptor
    device_type = observe
    port = 80
Offline droiddk
device_type needs to be this: wu-client
Please report back
« Last Edit: June 02, 2019, 01:58:29 PM by droiddk »
    • MétéWapi
Thanks for your help I managed to send the data to weewx.
I put this on
[Interceptor]
It works pretty well. I don't see much difference with wu-client
If you can enlighten me.
Offline droiddk
I put this on
[Interceptor]
Cool!
So, It is also working with "device_type =  wu-client" ?
Thanks Fine Offset / Ecowitt for building this customized upload option into their consoles, it opens not a whole new world!
Regards
    • MétéWapi
Yes, it works with both.
Observe and wu-client
Except wu-client gives more error type
raspberrypi weewx[7098]: interceptor: MainThread: unrecognized parameter absbaromin=26.82
Offline droiddk
Ok.
You can ignore that message, its a well know issue: https://groups.google.com/forum/m/#!topic/weewx-user/LWv_b0lkc3I
Do you use latest version of Weewx? Issue should be fixed in current release: https://github.com/matthewwall/weewx-interceptor/blob/master/bin/user/interceptor.py
Regards
« Last Edit: June 03, 2019, 04:22:30 PM by droiddk »
    • MétéWapi
Yes I use WeeWX Version 3.9.1
Which device_type to use to be 100% effective
And what are the real differences?
Offline droiddk
Not sure about this but you can check it yourself - check data on console and in weeex.
Regards
