Author Topic: Adding a new UOM  (Read 2462 times)
Offline floodcaster
    • Goose Lake Weather
Adding a new UOM
« on: January 20, 2009, 09:02:44 PM »
I wanted to add a new UOM of centibars for soil moisture on a page I'm creating in my ajax/php site. I tried adding $SITE['uomSoilMoist'] = ' cb'; in the Settings.php and then referencing that in my page but no luck. Is there a step I'm missing?
Bill
Offline WeatherBeacon
  • Chief
    • http://www.wxbeacon.com
Re: Adding a new UOM
« Reply #1 on: January 20, 2009, 09:18:57 PM »
Are you using VWS or WD?
Kevin...
Mae govannen!
« Reply #2 on: January 20, 2009, 10:30:22 PM »
If you're using the WD/AJAX/PHP template set, and you created a page using the wxnewpage.php as the starting point, then you should be able to <?php echo $SITE['uomSoilMoist']; ?> to print it on the page.
If you're not using the template set (or hadn't created a new page from the wxnewpage.php), then you may have to
include
<?php include_once("Settings.php");
global
$SITE;
near the top of the page, then use the above to print the value.
It would be helpful to have a URL to the page you're modifying :)
Best regards,
Ken
Offline floodcaster
« Reply #3 on: January 21, 2009, 05:40:54 PM »
Hi Ken,
Yes, using the WD ajax/php files and I've used the wxnewpage.php template.
Sorry, still new to PHP but this is a great learning experience!
I got it to work with:
<?php echo strip_units($fourinchsoilmoist) . $SITE['uomSoilMoist']; ?> </td>
Why wouldn't it work with:
<?php echo strip_units($fourinchsoilmoist) . $uomSoilMoist; ?> </td>
if in the page you have the code:
require_once("Settings.php");
I didn't include the URL as I just slapped together a table to see if my new additions to the testtags would work but it's here if you want to see it. Still messing with it and have a ways to go. ;)
Bill
Bill
« Reply #4 on: January 21, 2009, 07:19:19 PM »
Just putting it in the Settings.php file only ensures that $SITE['uomSoilMoist'] has content.  If you want to name a local variable as $uomSoilMoist   (like I have done with $uomTemp, $uomBaro ... etc in ajax-dashboard.php), then you'll need to include code like
if (isset($SITE['uomSoilMoist'])) {$uomSoilMoist = $SITE['uomSoilMoist'];} .. see the samples at the start of the ajax-dashboard.php.
Then (with the above code) you could use
in your page.
Hope this helps...
Best regards,
Ken
Offline floodcaster
« Reply #5 on: January 21, 2009, 07:27:50 PM »
Ahhh...I see what you mean. Thanks for the explanation Ken (and your patience) . :-)
Bill
« Reply #6 on: January 22, 2009, 01:54:31 AM »
You're very welcome!  Glad I could assist. :)
Best regards,
Ken
