I received my new weather station yesterday. Set everything up. Plugged in the bridge. Both blue lights came on. About five minutes later, light one started flashing. Light two remained solid. A few minutes later both lights went out. I tried unplugging and resetting several times. The best I could get was light two flashing rapidly....light one out....never comes back on....and the green and yellow lights on in the back.
I called support and left a message yesterday and again today. I assume because it's the weekend, support is limited or non-existent. I will try again Monday.
Do you think the unit is defective?
Based on this post- I can tell you exactly what happened.
After powering up the bridge, it will connect to the AcuLink service cloud and query the server for info- including the latest firmware update. If the firmware needs to be updated, the device will begin updating firmware within a few minutes usually- depending on traffic. The blue light on the left side of the bridge is the "uplink" indicator, the blue light on the right side is the "RF receive" indicator. During firmware download, the uplink indicator on the left will blink VERY rapidly as the bridge downloads the new firmware- it blinks so rapidly in fact (depending on your internet connection) that it never really fully illuminates- sometimes in a very well lit room it can look like it is off- but if you look VERY carefully from the side it is actually still functioning- its just in download mode. The right side LED (RF receive indicator) is solid, because RF is shut down during a firmware download process.
What happened in your case is the firmware update process was likely interrupted several times by powering down/resetting, etc., which of course the bridge software is designed to handle automatically and reboot itself and try updating the firmware over again. We always advise users to let the bridge "do it's thing" in the first 20 minutes or so of being powered on, it is an automatic process that works 100% of the time if left alone. In VERY, VERY rare cases, if you remove power and re-introduce it (plug, unplug, etc.), many devices can be affected negatively, the bridge included if all the planets align so to speak.
I am glad to hear we were able to help you in the end, I apologize it did not go so smoothly at first. I trust you will find the bridge and the AcuLink services very reliable now that you are up and running. Please let us know if there is anything else we can assist you with!
Thanks for choosing AcuRite!
Ryan
AcuRite Product Development Team
