Since you mention a 2 meter transceiver, I assume that you are a Ham.
I am using a Wx3in1 from
MicrosatIt is available here in the US from
Ham Radio OutletI really like this unit. I have a Davis Weather Envoy with
USB serial logger feeding the Wx3in1. I just have it uploading to APRS-IS. See it here:
http://www.findu.com/cgi-bin/wxpage.cgi?call=KE8DAF-13At aprs.fi, I have the temperature in the comment field. This is the indoor temperature, with the sensor right behind the Wx3in1.
http://aprs.fi/info/a/KE8DAF-13Here is a raw packet containing the temperature, it is in degrees C however. I don't know if it can be changed to °F, I haven't tried.
UPDATE: I looked up how to change to °F and it is very simple. In the line for the beacons, you just change <temp>C to <tempf>F@<date>z<lat>/<long>-PHG4120/WX3in1Plus2.0 U=<volt>V,T=<tempf>F
Now it shows:
2016-05-06 11:09:52 EDT: KE8DAF-13>APMI06,TCPIP*,qAS,KE8DAF:@061509z4525.03N/08348.63W-PHG4120/WX3in1Plus2.0 U=12.5V,T=65.3F
2016-04-30 07:41:40 EDT: KE8DAF-13>APMI06,TCPIP*,qAS,KE8DAF:@301141z4525.03N/08348.63W-PHG4120/WX3in1Plus2.0 U=12.5V,T=17.5C
I have this defined as a beacon in the Wx3in1.
@<date>z<lat>/<long>-PHG4120/WX3in1Plus2.0 U=<volt>V,T=<temp>C
I had a left over One-Wire thermometer IC Maxim DS18S20, that I used to sense the temperature. I had to add a pull-up resistor to get this to work though. Conveniently, there was a 5V spring-loaded socket right next to the 1-Wire data line to add it.
Note that the indoor temperature is
not coming from the Envoy, but from this external DS18S20. The Envoy may not suffer as much indoor temperature error as the consoles, but the remote sensor interfaced to the Wx3in1 can be located wherever you want.
I don't know what TNC or APRS software you use, but this Wx3in1 was a simple enough solution for this APRS-neophyte to get going.
Mateusz SQ3PLX, is really helpful and gives excellent support. If you order directly from him, it takes a couple of weeks to clear customs from Poland. No problem from HRO, but they didn't carry the cables that I needed so I ordered those from Microsat directly.
73 de KE8DAF
