Poll
How often do you check the accuracy of your tipping-bucket rain gauge?
I never have
7 (43.8%)
Only if it seems off
6 (37.5%)
Yearly
0 (0%)
Only when first installed (I don't trust the factory calibration)
0 (0%)
Every chance I get!
3 (18.8%)
Total Members Voted: 16
Author Topic: How often do you check the accuracy of your tipping-bucket rain gauge?  (Read 1704 times)
Offline nincehelser
Purely out of curiosity.
If you're one who has had to recalibrate, how far off have you been?
Offline DanS
  • Chiang Mai weather
    • ThaiWx
Re: How often do you check the accuracy of your tipping-bucket rain gauge?
« Reply #1 on: August 26, 2014, 07:30:48 PM »
I find that I need to get into them about once or twice a year to clean out the accumulated crud in the spoons but never needed to readjust the stops in them. (that I've noticed, against a manual gauge)
« Last Edit: August 26, 2014, 07:48:19 PM by DanS »
Offline wxtech
    • Lexington, Ga. Weather
« Reply #2 on: August 26, 2014, 07:50:23 PM »
I have tested more than 30 tipping bucket rain gauges.  Most test within 15% error so I don't make adjustments.  I test at 2 or more rain rates.  http://www.lexingtonwx.com/equipment/html/novalynx.html
Rain gauges should be cleaned often depending on what accumulates in the buckets or if spiders or bugs affect the operation of the mechanism.
Offline Old Tele man
  • Singing in the rain...
« Reply #3 on: August 26, 2014, 08:47:40 PM »
I clean the crud out every time I open it up, but I "...don't fix, what ain't broken..."
« Reply #4 on: August 26, 2014, 08:55:52 PM »
Being that my cocorahs gauge is about 8 inches away I check the accuracy with each rain fall.
Since I calibrated it a few years ago it remains pretty much even with the plastic gauge with the exception of heavy rain events where it under reports.
« Last Edit: August 26, 2014, 08:58:06 PM by ocala »
