Had a power failure and came down hard. Took 4-5 tries to get the PC back up, but VWS won't run. I get the "getting archives" and then "downloading records" (I assume from the davis) and then nothing. I checked dbase.csv, it's ok, deleted todays .bin file. Uninstalled and reinstalled, no change. Renamed VWS and copied in the total backup from 2 days ago, same thing, no change. Uninstalled and installed a complete raw new install, setup the Davis, get the same archives/records message and then nothing. Ok, where is it jammed? - the registry, or is there somewhere else? I've used this for over 9 years and never seen this one.
Thanks.
