I've been hard at it over the last week, working on oops's, issues and routines as I slowly implement Alt Dashboard 6 on my test system.
Most of the issues thus far have been fixed, or id'd in the to-be-fixed list, with one exeption - AQI.
I've looked at quite a number of Alt Dash sites, and see that the AQI is working on them, so I know it's possible.
I'm limited in my city /county because they no longer post actual readings, only the day1, day2 forecasts. So my approach has been to use the vanilla code in alt-dashboard and in get-aqi-rss.php, which seems to have 9, or Baltimore as it's default. No changes. I've looked at the gov. site, thru the url used, and data is being posted, so it should be there. I've got the switch to true to useAQI. But... It's not working / processing properly, as my AQI display does show 'Data not Available' and the 'no update received' image. I'd hoped to get it working, before I started figuring out of I can use 'forecast' data in lieu of the 'actuals'.
I'm wondering if I have the most current get-aqi-rss.php file. The author is no longer supporting scripts, so I've no way of telling.
I'm hoping some knowledgable helper can take a look and perhaps id the problem, or problems for me. I am NOT a coder, and it's kinda hard to find the details of 'wrongness' with my skill set.
Have attached the get-aqi-rss.php I currently have, plus a snippet of the AQI processing from within Alt Dashboard 6.
Ken
test.azkiwis.net
