I got my 4" rain gauge, and checked calibration today.
Something is seriously wrong with my VP2, or I've overlooked something major.
Initially I was getting about 1/3 the reading of actual rain, e.g., .3" in the cylinder would register about .11 on the VP2.
Thinking that might be a bit too crude, to just dump all the water in at once... I got a dropper, and one by one, dropped water into the cylinder until I got to .02", then added more to .03", then to .04".
I get about 38-39 drops per .01".
Next I used the dropper to drop water directly into the rain bucket, and it took anywhere from 87 to 91 drops (depending on cup) to tip the bucket.
Then I adjusted the screws upward (counter clockwise) until they were about to fall out, and still can't get it close.
Yes, I checked the level in all directions, and the fact that the difference between buckets was only about 4 drops leads me to believe it's level, otherwise there would be a greater disparity between volume required to tip the buckets.
I can't figure out what the problem might be... it just doesn't make sense...
