Author Topic: Can i add multiple acurite sensors to meteobridge?  (Read 3128 times)
Re: Can i add multiple acurite sensors to meteobridge?
« Reply #26 on: May 11, 2016, 03:56:10 PM »
Up to you.  It just move the pipe further from the mount if you get the long one.  But if you are putting a pipe up...
« Reply #27 on: May 11, 2016, 04:21:08 PM »
Last question if I hsve the 5-1 on channel A both console and sensor should I put the 3-1 on B?
Offline nincehelser
« Reply #28 on: May 11, 2016, 04:29:25 PM »
You can if you want, but it doesn't matter.
The channel just sets some identifier bits that the consoles use to discriminate devices of the same type.
The bridge doesn't care at all as it must listen to all devices anyway.
« Reply #29 on: May 11, 2016, 05:37:46 PM »
So you'd go with longer? The 3-1 is lighter then the 5-1 so that's a good thing. How high you think I should go with j-point before it moves around to much?
« Reply #30 on: May 11, 2016, 05:54:48 PM »
IIRC the pipe I used was eight feet so with the J-mount that gets it close to 9 feet up.  Good enough  for me.
« Reply #31 on: May 11, 2016, 06:30:30 PM »
Yea but that's if I get the smaller j-mount right? What about with the large J-mount? http://www.amazon.com/gp/product/B001DFS49U/ref=ox_sc_mini_detail?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
« Reply #32 on: May 11, 2016, 09:40:12 PM »
I dunno.  Have you considered measuring?
