Well it's obviously possible in software that reads LOOP data from the logger. From memory, OAT updates every 10 secs, so you could in theory calculate a running total of effectively eg the last 6 OAT updates (which would typically mean reading the last 24 LOOP packets and maintaining a mean value). I don't know of any software that does that, mostly I suspect because temperature typically doesn't change that quickly, but software, including WL, does track eg 2min mean wind speed which is a more pertinent parameter to look at as a short-term mean..
