Actually, I am using the GIS load shape files box. I misspoke above. Nonetheless, I still get both a SHP and STY file in there, press import, wait, nothing happens. I do tend to believe the files are at fault. I just don't know where else to go. I was using the GR3 Stuff site, but they are down. I looked at the GR3 forums, and they do give some files, but they are all written in code. I am not at that point yet where I know what to do with them.
I tend to believe that you DO know how to load storm icons and logos, but perhaps the software is bad, not compatible, who knows. It could be a fault in the GR3 program itself. But I will just keep experimenting with this. If it works okay for one file, then it should work okay for all the files unless the file is corrupted.
I guess we will both keep trying. I am going over to check out Allison House.
See you in a bit.
Greg
