I've discovered a problem with the THN132N temperature-only sensors. I have not seen this problem with other OS sensors. Unlike many OS sensors, this unit operates with a single 1.5V AA battery.
The problem is that temperature readings are significantly affected by battery voltage. These errors depend on how far you are from a "golden point" of 25C. In other words, if the temperature is 25C, battery voltage is irrelevant. On the other hand, if the temperature is 0C or 40C, errors can be as much as 0.8C. And at -20C the errors can reach 1.4C or more.
I've attached a graph showing measurements I've made of changes in reported temperature as battery voltage is varied between 1.2V and 1.6V. These errors are relative to the reported temperature with a battery voltage of 1.5V. This sensor is not functional at 1.1V and below.
I have performed similar tests on OS temperature/humidity sensors which run on two 1.5V batteries (THGR122NX, THGN123N, THGR801N, THGR810) and they are rock-solid. No change in reported temperature for battery voltages over the range from 2.0 to 3.0V.
