Author Topic: wxstatus missing radar status window  (Read 1172 times)
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« on: March 04, 2018, 12:39:46 PM »
Yesterday my http://tiggrweather.net/wxstatus.php page dropped the yellow radar status box that used to appear in the middle of the file listings (even when status was active as it is now). Everything else seems to be showing. I think all my files are up to date.
Thoughts appreciated.
W7JKG
Re: wxstatus missing radar status window
« Reply #1 on: March 04, 2018, 03:11:25 PM »
Strange.  I do view-source:http://tiggrweather.net/radar-status.php?cache=1&nexrad=KIWA&show=active and see
<!-- radar-status.php V1.15 - 22-Feb-2017 -->
<!-- loading ./radar-status.txt from http://radar3pub.ncep.noaa.gov/rcvxmit.sites.public.html -->
<!-- curl fetching 'http://radar3pub.ncep.noaa.gov/rcvxmit.sites.public.html' -->
<!-- HTTP stats:  RC=200 dest=140.172.138.16 port=80 (from sce=208.131.135.7)
      Times: dns=0.125 conn=0.144 pxfer=0.144 get=0.041 total=0.185 secs -->
<!-- appending ./radar-status.txt from http://radar3pub.ncep.noaa.gov/ftm.txt -->
<!-- curl fetching 'http://radar3pub.ncep.noaa.gov/ftm.txt' -->
      Times: dns=0.000 conn=0.019 pxfer=0.019 get=0.022 total=0.041 secs -->
<!-- cache written to ./radar-status.txt. -->
<!-- 203 records found -->
UTCdate    =1520193783 (2018-03-04 08:03:03)
lastUTCdate=1520193485 (2018-03-04 07:58:05)
<div style="border: dashed 1px black; background-color:#FFFFCC; margin: 5px; padding: 0 5px;">
<p>NEXRAD Radar KIWA status: <span style="background-color: #33FF33; padding: 0 5px;">Active</span> [last data 0:04:58 h:m:s ago]<br />as of Sun 04 Mar 2018 1303 MST</p>
<p><small><a href="http://radar3pub.ncep.noaa.gov/">NWS WSR-88D Transmit/Receive Status</a></small></p>
</div>
which looks normal to me.
The default for radar-status.php is to NOT display a box if the NEXRAD radar is 'Active', so the box won't be displayed below the GR3Radar check in that case.  If you want it displayed, insert in Settings.php
$SITE['showradarstatus'] = true; and that will force the script to always display the box.
Offline jgillett
« Reply #2 on: March 04, 2018, 07:09:50 PM »
That's really weird, Ken. Have made no changes at all that would affect this. The active box has been there forever (not that I miss seeing it gone). PSR had a down time message up on 1 March, expiring on 1 March. Their messages always remain for a few days even after the expiration date/time. When the message finally went away the active message never returned.
Thank you.
W7JKG
Offline lstrip
« Reply #3 on: March 08, 2018, 08:52:20 PM »
Could you tell me how you add Hardware status to you wxstatus.php?
Larry
vancamweather.com
Offline jgillett
« Reply #4 on: March 09, 2018, 12:43:35 AM »
Larry, here's the code that I use...
<?php print "<hr/><p align=\"center\"><b>Hardware Status</b><br/>\n";
print
"Vantage Pro2+ ISS Battery Status: <b>$vpissstatus</b><br/>\n";
print
"ISS Packet Reception: <b>$vpreception2</b> of all packets received<br/>\n";
print
"Console Battery Voltage: <b>$vpconsolebattery</b> volts<br/>\n";
print
"<a href='http://strikestarus.com/StrikeStarUS_Stats.html' target='_blank'>NexStorm Network Status</a>: <b>$percent&nbsp;&nbsp;$reliability</b><br/>\n";
print
"</p><hr/>";
W7JKG
Offline lstrip
« Reply #5 on: March 09, 2018, 05:22:07 PM »
Thanks John
Can you explain where that would be inserted into wxstatus.php?
I tried and get server error.
Offline jgillett
« Reply #6 on: March 09, 2018, 08:20:59 PM »
Basically it can go pretty much wherever you want. Here's where it is on my page (line numbers not mentioned because yours and mine may be different)...
<a href="http://radar3pub.ncep.noaa.gov/" target="_blank">US Radar Sites Status</a><br />
print
print
print
print
print
"</p><hr/>";
  <p align="center"><b>*NOTE:</b> StormVue NGX Updates are activity dependent. When lightning strikes within detector range are sparse, uploads are much less frequent and will often show as '<span style="color: red"><b>NOT Current</b></span>'.</p>
  </center></div>
  <?php } else { // software not defined yet ?>
  <p>&nbsp;</p>
  <p>Weather Software not yet specified .. no status to report.</p>
  <p>&nbsp;</p>
  <p>&nbsp;</p>
  <p>&nbsp;</p>
  <?php // end software not defined ?>
</div><!-- end main-copy -->
</center>
<?php
include("footer.php");
# End of Page
So this is within the main div and just above the footer.
« Last Edit: March 09, 2018, 08:25:43 PM by jgillett »
W7JKG
Offline lstrip
« Reply #7 on: March 10, 2018, 07:32:35 PM »
Thanks for your help.
Finally got it working by inserting at the top of page.
Everytime I put it below the wd status, I would get a server error.
Thanks again
Larry
http://www.vancamweather.com/wxstatus.php
Offline jgillett
« Reply #8 on: March 10, 2018, 07:36:39 PM »
Attach your script here.
W7JKG
