And now it is my turn to provide testing data.
Like some others I'm testing the product on a different computer than is used for my everyday weather needs.
This one is a homebuilt Win 7 64 bit system, without a serial port.
The USB to Serial port cable I'm using is from ATEN
http://www.aten-usa.com/?product&cat=795&Item=UC232A Now oddly enough neither the VWS and Cumulus software had any problems with station recognition or the data feed. However the Weatherlink software turned into being the odd man out.
Not really any sort of a big deal as the cable I'm using is now so old I no longer can recall when I purchased it. Also at the time of its purchase it was for the programming of a handheld police scanner as I was out of available serial ports. And it still works with the scanner and related software.
In going back to the WL software it sort of thinks something is there but can't quite resolve the problem, If I do the Autoscan routine it will stop on the right port for quite some time and then decide there isn't something there afterall, and if do the Test routine it runs all the way to the end of the timeout period before giving up.
I've tried 2 different USB ports as sometimes that can make a difference.
In any event the product is a winner and the above information is as much as anything to let others know that it is probably best to avoid that particular ATEN cable, which is still in production.
Bob
