Author Topic: Meteotemplate - new free website template  (Read 630558 times)
Offline weatherbee
    • Sherman Ct. Weather
Re: Meteotemplate - new free website template
« Reply #5950 on: February 26, 2017, 04:11:11 PM »
When you run setup database it will test it.
Offline jeffm5690
    • Long Island New York Weather
« Reply #5951 on: February 26, 2017, 04:13:42 PM »
Test in the Main Setup shows it is OK:
Success: A proper connection to MySQL was made!
Table already exists.
But obviously it is not.
Offline weatherbee
« Reply #5952 on: February 26, 2017, 04:16:43 PM »
If it makes a proper connection I don't know what is wrong.  I wouldn't rush to erase the data.  I'm sure Jachym will figure it out.
Tom
Offline jeffm5690
« Reply #5953 on: February 26, 2017, 04:32:45 PM »
Tom
Yep.  I did run the testupdate.php and see the following which may have some reason for this:
Update Test
Checking validity of data based on your limits in Main settings...
Checking date and time...
There seems to be a problem with the date and time. Either it has not been parsed correctly or it is a date/time in the future! Check the format you specified and also the actual values.
Minimum temperature allowed: -15 F
Maximum temperature allowed: 110 F
Temperature is outside the allowed limits! Temperature value will be ignored!
Minimum humidity allowed: 0 %
Maximum humidity allowed: 100 %
Humidity OK.
Minimum pressure allowed: 28 inhg
Maximum pressure allowed: 33 inhg
Pressure is outside the allowed limits! Pressure value will be ignored!
Minimum wind speed allowed: 0 mph
Maximum wind speed allowed: 200 mph
Wind speed OK.
Minimum wind gust allowed: 0 mph
Maximum wind gust allowed: 200 mph
Wind gust OK.
Minimum daily precipitation allowed: 0 in
Maximum daily precipitation allowed: 200 in
Daily precipitation OK.
Minimum rain rate allowed: 0 in/h
Maximum rain rate allowed: 500 in/h
Rain rate OK.
Minimum wind direction allowed: 0 degrees
Maximum wind direction allowed: 360 degrees
Wind direction OK.
Calculating dew point based on parsed values...
Temperature or humidity or both are not valid. Not possible to calculate dew point.
Calculating apparent temperature based on parsed values...
One or more parameters from the following: temperature, humidity, wind speed, are not valid. Impossible to calculate apparent temperature.
Summary
There is a problem with the date and time, nothing would be imported. Check the date/time format you specified and the actual values in the file.
Offline jeffm5690
« Reply #5954 on: February 26, 2017, 05:19:59 PM »
Not sure how but I fixed it.  TY
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #5955 on: February 26, 2017, 05:46:37 PM »
This again seems like a server issue, if the script now works, there is no way it could be a script problem if you did not change anything in the code. With PHP code it is either or. EIther it works or it doesnt, but its not like it works for an hour and then not again...
Seems you just have extreme bad luck... hopefully it will work now. I think the scripts I fixed yesterday are also working fine (Bloomsky, indoorData). Looking at your site now, all seems fine.
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update - Dynamic Text 2.1
« Reply #5956 on: February 26, 2017, 06:41:07 PM »
Hi guys,
bug fixes ;)
Enjoy
Offline jeffm5690
« Reply #5957 on: February 26, 2017, 06:48:22 PM »
Thanks - all looks good now.  Will see how it goes over the next 24-48 hours before I update any blocks, etc
Offline Jáchym
    • Meteotemplate
« Reply #5958 on: February 26, 2017, 06:55:54 PM »
If this host has issues again (!) I guess the only option left would be me hosting your site on my server and redirected from your domain :D
Offline jeffm5690
« Reply #5959 on: February 26, 2017, 06:58:12 PM »
Lol....  if this happens again I'm giving up and just sitting by a window with a rock and if the rock gets wet then it's raining..,
Offline KapitainOne
    • Sanford Weather
Re: Meteotemplate - Block Update - Dynamic Text 2.1
« Reply #5960 on: February 26, 2017, 07:07:56 PM »
Hi guys,
bug fixes ;)
Enjoy
That seems to have fixed my issue, thanks  =D>
Offline Jáchym
    • Meteotemplate
« Reply #5961 on: February 26, 2017, 07:19:12 PM »
np, thanks for letting me know
Offline stewart45
    • Newlands Weather Station
« Reply #5962 on: February 27, 2017, 05:08:00 AM »
Still getting a blank block in Dynamic Text (not disappearing) have updated to version 2.1 have I got the menu setup properly
Offline Jáchym
    • Meteotemplate
« Reply #5963 on: February 27, 2017, 05:25:21 AM »
Hi Stewart,
Im not sure why you are using the menuBlock syntax for a single block. Just use a normal block syntax, thats what you want. See the PDF I made in the wiki about block layouts with examples.
In your case, simply use:
ssGauges
dynamicText
multipleBlock.....
Offline stewart45
« Reply #5964 on: February 27, 2017, 05:42:25 AM »
My mistake, sorted now, a case of if in doubt read the instructions  :oops:
Offline Jáchym
    • Meteotemplate
« Reply #5965 on: February 27, 2017, 06:32:40 AM »
No problem Stewart, glad it is working fine now
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update - Steel Series Gauges 2.1
« Reply #5966 on: February 27, 2017, 06:51:36 AM »
Hi guys,
added possibility to enable/disable the time at the top.
Enjoy
Offline nineback
    • Albertville, AL Weather
« Reply #5967 on: February 27, 2017, 09:38:55 AM »
I am using the newest version of the forecast block and have it configured for Weather Underground and installed my WU API.  The block keeps saying Forecast currently not available.  Anyone else using the Forecast Block with WU and have it working? I see it appears to be working on the demo site at Brno.
Does anyone know if the API is specific to a particular subdirectory under the main domain or is it good for the whole domain.  For example will weather.kq5s.com and www.kq5s.com use the same API?
Tom
Davis VP+
Weather Display/WeeWX
http://www.kq5s.com/
Offline Jáchym
    • Meteotemplate
« Reply #5968 on: February 27, 2017, 09:41:03 AM »
the WU API key is not specified for a particular referrer, which is why you dont see it in the HTML too, it is just in the PHP section and it simply has a daily quota which can be used by anyone who knows this key.
This is strange, the only thing I can think of is that the location for WU is not correct, did it ever work?
Offline nineback
« Reply #5969 on: February 27, 2017, 09:47:57 AM »
I don't remember if it worked on your template or not.  It has worked before on other software.  I have changed to location and get the same result.  If there is a problem with my key will I get the same message saying Forecast currently not available?
Davis VP+
Offline Jáchym
    • Meteotemplate
« Reply #5970 on: February 27, 2017, 10:07:43 AM »
Send me what you have for your location and i will try it on my server
Offline nineback
« Reply #5971 on: February 27, 2017, 10:09:39 AM »
I have tried Albertville and Huntsville both in Alabama.
Davis VP+
« Reply #5972 on: February 27, 2017, 10:18:56 AM »
I have had no issue with the WU forecast which I use as default as the Yahoo was often Not Available.
Jachym,
Again I see a css and icons folder in my existing fireDanger block that is not in the new v.2.1.  Maybe this is remnants of  v.1.1 that I should have removed with the v.2.0 update?
Offline KapitainOne
    • Sanford Weather
« Reply #5973 on: February 27, 2017, 10:44:48 AM »
I recently tried to use the dynamicImage Block to display a couple of images, up until now I'd just had one.
No luck, the images display one above the other, not cycling as I think it should.  Uploaded the block again, checked permissions, triple checked that I'm using a ; between the url's etc etc
Baffled! Any other things I should look at??
Can be seen near the bottom of my home page just above the NASA Image
Bill
Offline Jáchym
    • Meteotemplate
« Reply #5974 on: February 27, 2017, 11:10:21 AM »
I see them and I dont see any problems with them
