Author Topic: Davis bucket calibration  (Read 15981 times)
Re: Davis bucket calibration
« Reply #75 on: August 06, 2017, 06:15:06 PM »
So.... If I use the Novalynx rain gauge calibrator for my Davis VP2 rain gauge, would it improve the accuracy of the Davis gauge?
I would think so. You would at least know if the gauge is capable of repeatability. If not and it's very possible if like my Davis gauge and all over the place replace with Rainwise 111 8". https://www.rainwise.com/products/detail.php?ID=6697
Thanks! How do you get the RW gauge to report to the Davis console or to WeatherUnderground etc. in one piece?
rj11 phone line Green/yellow together go on 1 post and red on other rainbucket terminal. Black is not used.
Fancy, smancy, I just twisted mine together. ;)
« Reply #76 on: August 06, 2017, 07:46:43 PM »
While I haven't touched my own VP2 in regards to rain calibration, I'm curious about how others measure the bucket tips without upsetting their live data.
It would make simple sense to me to unplug the rain sensor from the ISS & patch it into a micro (Micromite, Arduino etc), and then log the tips in there.
Has anyone tried that sort of approach?
It would make it easy to log the bucket tips along with time stamps & compare results at different "Rain rates".
Phil.
The rainwise has a counter that comes with unit for easy calibration but for davis tipping bucket station you could wire a no voltage counter.
https://www.amazon.com/gp/product/B009NC9M0U/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
https://www.amazon.com/Baomain-H7EC-BLM-Counting-No-voltage-Required/dp/B00W16DLFC/ref=pd_sim_469_2?_encoding=UTF8&psc=1&refRID=AFX1J3ZQ579TVVCQRF30
« Reply #77 on: August 06, 2017, 07:55:32 PM »
You can wire both Iss rj11 plug and RW counter plug to posts at same time just pop the blue cover off and post are exposed. I left a section of wire with counter plug coiled up under cover so if I ever need a calibration it's ready to go. Just unplug from Iss and plug counter in.
« Reply #78 on: August 06, 2017, 08:08:15 PM »
Ah yes, that's a hellofalot easier your way.
Offline WheatonRon
    • WUnderground
« Reply #79 on: August 06, 2017, 09:12:45 PM »
Where does one buy a Novalynx calibrator gauge at a reasonable price, and what is that reasonable price?
Offline jgentry
« Reply #80 on: August 06, 2017, 11:22:26 PM »
If I go decide to get the RW gauge, do I need to calibrate it out of the box or does it perform well right off the bat?
« Reply #81 on: August 07, 2017, 01:02:48 AM »
They are hand calibrated, but some people I know had to jack with it outta the box and screw it up. I, uhummm, I mean they got it back.  :roll:
Offline jgentry
« Reply #82 on: August 07, 2017, 07:13:17 AM »
Gotcha.
Can you & ValentineWeather both send me pics on how your RW gauge is installed relative to the Davis ISS location? I'm trying to think of a way to install the RW gauge without much fraying of the wire of the RW gauge.
« Reply #83 on: August 07, 2017, 08:51:43 AM »
Only place I know is retail directly from Novalynx. 260-2595 Tipping Bucket Rain Gauge Calibrator  - $125.00
This is the best field unit I've found because unlike most other rain gauge calibrators flow slows with head pressure. These keep same drip speed throughout calibration.
« Reply #84 on: August 07, 2017, 10:01:48 AM »
Gotcha.
Any rain gauge needs mounted securely. I've mounted RW gauges on top of cinder block drilling and screwing down into block,  another is mounted on large heavy block of wood. Main thing it's mounted securely and not swaying or vibrating with the wind. It's been covered before but many pole mounted gauges are prone to tip early from vibration causing gauge to read high or sometimes normal on under calibrated gauges but then a rain with little wind if gauge is under calibrated will be short. You end up chasing your tail basically not understanding why one time it was close and short another.
How you protect the wire is your choice if gauge is located some distance away from ISS I run underground in pvc pipe. If you want wire can be exposed on top but I would replace every few years.
It's easy to hook up this is one of my backup gauges with Davis heater I was experimenting with. Just pop blue cover off and wire. Red goes on one post, green yellow on other.
Offline jgentry
« Reply #85 on: August 07, 2017, 11:13:49 AM »
Gotcha.
Ok. Thanks!
« Reply #86 on: August 07, 2017, 03:41:31 PM »
Mine is also screwed into the cap of a cider block wall, makes it easy to balance too. As far as the line to the ISS, I used just the phone cord itself running through the desert (knew it wouldn't last) and sure enough was chewed through within a week. So I got smart and fished it through a garden hose (talk about a PITA), that got chewed through the next day (really, what the hell I got out here?) Soooo, I really got smart and fished it through flexible metal conduit, 10 times easier than the hose, and knew that's how I should have done it in the first place. :roll: That was the first of the year and ain't nothin' chewed through that. =D>
Offline jgentry
« Reply #87 on: August 12, 2017, 07:44:09 PM »
Gotcha.
Can the RainWise RainNew gauge be installed on a mast like their rainlogger gauges?
Offline jgentry
« Reply #88 on: August 12, 2017, 08:35:05 PM »
And btw Randy, how does the RainWise gauge compares to your Texas Electronics gauge?
« Reply #89 on: August 12, 2017, 08:45:30 PM »
Both work the same. The TE is just made of higher quality material and should last long time.
« Reply #90 on: August 12, 2017, 08:47:08 PM »
I like that..Look into it and report back what's needed.
« Reply #91 on: August 12, 2017, 09:12:47 PM »
Yes, it looks cool, but with that really high center of gravity I wonder about shimmy in stronger wind. That's the whole reason why I left my VP2 rain bucket on a tripod for the RW, the RW is completely solidly mounted.
Offline jgentry
« Reply #92 on: August 12, 2017, 09:35:39 PM »
Just emailed RainWise. Waiting for a response from them.
« Reply #93 on: August 12, 2017, 09:44:28 PM »
Nice, I look how it looks if nothing else... :grin:
Offline twcmaster
« Reply #94 on: August 13, 2017, 12:40:31 AM »
Thanks for sharing this great info!! I saw this post as heavy showers were approaching and decided to quickly hook up my no longer used Rainwise MKIII rain gauge last night. I measured:
RainWise .28
Davis (as calibrated as I can get it)  Aerocone .26
Cocorahs 4" Manual (non-electronic): .28
Novalynx 8" Standard Manual (non-electronic): .31
Thanks again!
Offline Mattk
« Reply #95 on: August 13, 2017, 03:49:04 AM »
Sounds like the old saying, a man with 1 rain gauge knows how much rain, man with 2 rain gauges is never quite sure.
Offline jgentry
« Reply #96 on: August 14, 2017, 11:09:19 AM »
« Reply #97 on: August 14, 2017, 11:17:59 AM »
Cheaper than the Texas Electronics base however.
« Reply #98 on: August 14, 2017, 11:20:56 AM »
What's nice about having a base it takes all the mounting issues away plus gauge can be precision leveled .
Offline twcmaster
« Reply #99 on: August 14, 2017, 11:25:13 AM »
Does it have to be cemented into the ground?
