Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
Hello Moe. Are you considering painting? I did lock the topic a couple of times to try to cool nince off, but he just won't consider trying to work with those of us who are testing the paint on the bottom housing of the sensor. I am seeing such an improvement, and my data agrees with our two local ASOS and a Davis. The only thing I find lacking is the humidity running too low when it should be near 100% It runs about 8 low.
Is this roof mounted?my station is at 5' standard height!
The color is dark enough (grey) that it absorbs enough sun to raise the temp on the chip which is located inside the gray bottom of the 5 in 1 to cause a real mess for about 2 hours in the morning, and then 2 hours in the evening as the sun sets.
During an all cloudy day, with low wind, I am still seeing a 4 degree spike on my 5 n 1. Any ideas what I should paint to try and get the chimney effect going? Paint under the cover maybe, where the fan blades are? The stack of the wind cups and the cups themselves? I have no extra heating when the sun is out, like I do when it's cloudy. I can't figure where the heat comes from... Maybe the electronics?
