Weather Software => WeatherLink/weatherlink.com by Davis Instruments => Topic started by: JECO on November 06, 2017, 07:48:17 PM
I had to remove everything because of system files corruption. I copied all my files, so now I am looking for my weather station files to restore. What files do I need to restore to restablish my my weather station. Hope I have made my question clear.
Find the file that you named your station. Copy that.
If you need to reinstall- do that. Then drop the file in the same place as the install.
Open WL
File tab-Open station. Select said station.
Should be it. It will have your settings, templates, data, info.
Thank you Chief David!
