Hi All!
Recently, I discontinued using my hosting service to run
heightsweather.info using webserver software on my Synology NAS.
The changeover went (for me) surprisingly smoothly - I am still very new to all of this -- EXCEPT that my Atom Warnings are now not working.
I ran what I think is the newest version (1.23) of check-fetch-times.php and received the following result (which I excerpted below, although I attached a snapshot of the complete output):
_______________________________________________________________
Error: Unable to write to ./cache/forecast-NJZ104-test-json.txt file.
Test was NOT successful.
--end NWS Forecast URL check --
Error: Unable to write to ./cache/atom-advisory-NJZ104.txt file.
--end NWS Warning Zone ATOM/CAP Feed check --
Error: Unable to write to ./cache/uv-forecast.txt file.
I am still working on figuring out how to get my old CRON job working, so in the meantime I changed the GENERAL SETTINGS in nws-alerts-config.php to the following
## GENERAL SETTINGS
$noCron = true; // true=not using cron, update data when cache file expires
// false=use cron to update data
I think that I should be automatically updating my two zones without using cron, but no luck.
I KNOW - unequivocally - that the fault is mine: I am doing something incorrectly. Can someone please tell me what I am doing wrong?
Many Thanks.
