Author Topic: Connecticut Station: Acurite 5 in 1 Pro Plus  (Read 1598 times)
Offline Glenn
« on: November 10, 2017, 06:45:03 PM »
I had issues posting via mobile previously, hopefully this works!  I took these pics in late August.
A few shots of the station mounted to our shed in the flatlands.  It's been working well for the last few months. I love having remote access to conditions!  The HD display is the first thing I check when I make my way to the kitchen in the morning.
I used a this to ensure the mounting pole was plumb.  Worked perfectly!
Same antenna mount I used on the station up in Vermont.
Acurite 5 in 1 Pro+
Southern VT
Connecticut
Offline C P RON
Re: Connecticut Station: Acurite 5 in 1 Pro Plus
« Reply #1 on: November 11, 2017, 02:35:20 PM »
Looks solid,nice job  Thanks for posting
C P RON
Ambient WS-2080 on last legs
9/11 Never Forget
Offline Glenn
« Reply #2 on: November 11, 2017, 04:49:06 PM »
Debating if I should switch to the lithium batteries fir the winter.
Acurite 5 in 1 Pro+
Southern VT
Connecticut
Offline nincehelser
    • nincehelser.com
« Reply #3 on: November 11, 2017, 04:56:10 PM »
I would.  I use lithiums year-round in my 5n1s.
I always change mine in the fall even if I'm not getting a low battery warning.   That way I can avoid a battery change in the dead of winter.
Offline C P RON
« Reply #4 on: November 11, 2017, 04:58:22 PM »
I always  use them  they do well in our cold winters and seem to last just as long if not longer they other batteries
« Last Edit: November 11, 2017, 05:01:59 PM by C P RON »
C P RON
9/11 Never Forget
Offline BeaverMeadow
« Reply #5 on: November 11, 2017, 06:09:36 PM »
I just picked up a 12 pack from Amazon:
https://www.amazon.com/gp/product/B004V2HF92/ref=oh_aui_detailpage_o01_s00?ie=UTF8&th=1
Offline Glenn
« Reply #6 on: November 14, 2017, 08:08:56 AM »
Thanks guys. Sounds like it may be a good project to do sooner than later.
Acurite 5 in 1 Pro+
Southern VT
Connecticut
Offline hotsauce2007
    • Weather Station
« Reply #7 on: November 17, 2017, 04:02:15 PM »
Pretty nice,
I wish I could use power supply on mine, I hate the idea of use batteries  ](*,)
Offline Glenn
« Reply #8 on: November 17, 2017, 04:16:06 PM »
That certainly would be nice! Unfortunately, both of my systems are mounted far away from any power sources. At least they have some solar operability with the internal fan.
Acurite 5 in 1 Pro+
Southern VT
Connecticut
Offline Rising Barometer
« Reply #9 on: December 08, 2017, 11:01:36 PM »
Nice setup !
Mine is similar out here in Western Washington.
Acurite makes a remote battery pack with a 30 ft wire: https://www.acurite.com/remote-battery-pack-for-5-in-1-weather-sensors.html which I am considering.
These high installations are hard to get to and you have to be careful not to fall.
Offline Glenn
« Reply #10 on: December 11, 2017, 11:31:29 AM »
Good idea on the battery pack! That would make changing easier. Thankfully, the snow we had yesterday melted/blew off from the unit. Not so much in VT. I had to use a long handle to reach the unit and clear the wind cups.
Acurite 5 in 1 Pro+
Southern VT
Connecticut
