Author Topic: IE 11 issue  (Read 4868 times)
Offline dupreezd
Re: IE 11 issue
« Reply #25 on: May 09, 2017, 08:54:13 PM »
When I type in 192.168.1.1 on the pc connected to the tplink wifi router, it brings up the Lynksys router page.
Is this not a webpage?
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
Re: IE 11 issue
« Reply #26 on: May 09, 2017, 10:24:41 PM »
It is, but that doesn't show if the correct ports are open.
Software: WeatherDisplay
Offline hankster
    • NFM Weather
Re: IE 11 issue
« Reply #27 on: May 09, 2017, 11:48:46 PM »
Can any other devices like other computers, tablets or cell phone access http sites?
  • Mark
Re: IE 11 issue
« Reply #28 on: May 11, 2017, 11:12:39 PM »
So it turns out, its the 2nd modem I have hooked up that's causing the issues. I've read a lot about running 2 modems and have tried the suggestions on settings, but obviously that's not working.
Offline dupreezd
Re: IE 11 issue
« Reply #29 on: May 12, 2017, 08:55:47 AM »
Good job finding it.
When running two modems or routers, it is best not to use the WAN connector on the inside network. Just use the LAN switch ports. Ok, you loose one port for the uplink to the other router but it makes life much easier.
Also, if you use the DHCP option in the router, make sure you only run it in one router. Otherwise you might experience IP address clashes if the hand out address in the same address range.
CWOP - FW0717
Blitzortung 2100
  • Mark
Re: IE 11 issue
« Reply #30 on: May 12, 2017, 09:05:56 AM »
Ill double check all my settings later and let you know.  Thanks
  • Mark
Re: IE 11 issue
« Reply #31 on: May 12, 2017, 10:00:37 PM »
I disabled DHCP on the 2nd router inline, and still having the same issues. Also, not using WAN on the 2nd router.
  • Mark
  • Mark
Re: IE 11 issue
« Reply #34 on: May 13, 2017, 11:04:19 AM »
I did end up ordering a switch. Hopefully that will solve my issues.
Offline dupreezd
Re: IE 11 issue
« Reply #35 on: May 21, 2017, 02:34:20 PM »
Did you get your problem resolved?
CWOP - FW0717
Blitzortung 2100
  • Mark
Re: IE 11 issue
« Reply #36 on: May 23, 2017, 09:13:34 AM »
Yeah,  i removed the 2nd router and put a switch in. That fixed the problems.
