I just hopped on board and bought myself a Davis Vantage Pro 2 6152. It was a steal of a deal but that is another story. I have a question about elevation. According to the guide it seems as though I should be entering in feet the elevation my location is above sea level, which is ~18 ft. The question is, should I be entering the elevation of the property that the station is on, or should I be using the real elevation of the station itself ( Sea-level + Mast, 18'+15') ? I have done a little digging, but I am still not sure on the issue. The Mast itself is in the ground and mounted to the side of the house, as a regular Antenna mast, with the ISS about 5 feet above the roof level (~15' from the ground to the ISS), in a sheltered corner of the house below the tree line and the Anemometer is about another 5 to 10 ft up from the ISS.
