Author Topic: Fall 2016  (Read 26420 times)
Re: Fall 2016
« Reply #200 on: November 24, 2016, 02:43:03 PM »
I walked a 5k this morning and it was 34. Not a bad morning. But I am sore.
Offline WeatherHost
Re: Fall 2016
« Reply #201 on: November 24, 2016, 02:51:13 PM »
I walk 4 miles nearly every morning, weather and other conditions permitting, plus another 1 1/2 or so in the afternoons.  If I can't do it outside, I try to do 30 minutes on a treadmill inside which seems to take as much or more out of me.
Offline Scalphunter
Re: Fall 2016
« Reply #202 on: November 25, 2016, 07:17:11 PM »
:  Alaska Temperature Extremes.
:  Highest Temperature Last 24 Hours.
:   47 at Kodiak
:  Lowest Temperature Last 12 Hours.
:  -30 at Northway
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #203 on: November 25, 2016, 08:05:07 PM »
:   47 at Kodiak
:  -30 at Northway
Sounds cold. Why do you list the highest temperature in the last 24 hours, but the lowest temperature over the last 12 hours? Just curious.
« Last Edit: November 25, 2016, 09:00:21 PM by WheatonRon »
Offline Scalphunter
Re: Fall 2016
« Reply #204 on: November 25, 2016, 09:45:27 PM »
Lowest is the night time temps. That is the way NWS post them here in their summary .
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #205 on: November 25, 2016, 09:57:35 PM »
You learn something new every day!
Offline Scalphunter
Re: Fall 2016
« Reply #206 on: November 26, 2016, 03:04:44 PM »
:   50 at Atka
:  -28 at Buckland
Here at  the cabin  my low and my high for today so far is 18 below zero.   out in the  Chain   big storm  moving thru 65-70  MPH  winds with sea height forecasted up to 42 feet.
Re: Fall 2016
« Reply #207 on: November 26, 2016, 03:18:46 PM »
I had a couple of Christmas lights come off the roof, so I had to go out today and reconnect them.  Warm, sunny, no wind, snow melted.
There were two house flies on the room, happy as can be. Even though it has been "cold" It is not enough to get rid of the flies and the geese. We have had just a few hours below 32F and a few snow events.
Offline Scalphunter
Re: Fall 2016
« Reply #208 on: November 27, 2016, 03:55:35 PM »
:   49 at Annette...Dutch Harbor
:  -30 at Shungnak
 Well from 18 below we warmed up yesterday to  minus 7  then plunged to 16 below  last night before the southerly flow aloft  started to bring temps back up. Today we are  getting light snow.
 also that storm I mention in the Chain  at false Pass they clocked  winds of 100 mph.
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Fall 2016
« Reply #209 on: November 27, 2016, 04:13:25 PM »
Nice :-)  - and Im not being ironic.... I really prefer night, dark, cold :D Yeah.. Im weird :D I think I might consider moving to Alaska, Im sure I would enjoy the weather there :D Im just not a big fan of the long summer days :D
Re: Fall 2016
« Reply #210 on: November 27, 2016, 06:11:46 PM »
Long summer days are fine as long as they end with massive thunderstorms. :grin:
Re: Fall 2016
« Reply #211 on: November 27, 2016, 07:44:04 PM »
Check out the altimeter in N. Nebraska Pressure: 29.08 inHg. This is really low, never experienced pressure drops like this in Arizona. Shows how accurate the Davis Vue pressure is also dead on with airport.
Re: Fall 2016
« Reply #212 on: November 27, 2016, 07:49:32 PM »
Wow, that's deep, and sitting right on top of you. Glad the Vue keeping up too! =D>
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #213 on: November 27, 2016, 07:53:48 PM »
Last year we had 28.8 here which is very unusual
Re: Fall 2016
« Reply #214 on: November 27, 2016, 07:57:34 PM »
For anyone interested the VP2 console is reading higher (29.14 in) because it doesn't have altimeter adjustment.
This is why some of us use the Vue as main console.
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #215 on: November 27, 2016, 08:10:37 PM »
Someone in this Forum suggested I set my elevation on the VP2 console to zero, then adjust my barometric pressure to that reported by a nearby airport and all should be good. I did, now my pressure is very close to altimeter readings reported by nearby reliable stations.
« Last Edit: November 27, 2016, 08:12:44 PM by WheatonRon »
Re: Fall 2016
« Reply #216 on: November 27, 2016, 08:13:12 PM »
I am, and that's just about where I figured the VP2 would be, as it's error seems quite linear.
Re: Fall 2016
« Reply #217 on: November 27, 2016, 08:18:55 PM »
Probably me. It will remain fairly close until you get into real high or low pressure as Randy is seeing now. The stronger the high or low, the greater the error.
Re: Fall 2016
« Reply #218 on: November 27, 2016, 08:22:23 PM »
Poorly stated on my part saying "error". The VP2 is doing it's job, it just doesn't do the altimeter setting.
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #219 on: November 27, 2016, 08:23:43 PM »
Poorly stated saying "error". The VP2 is doing it's job, it just doesn't do the altimeter setting.
And the Vue does a better job? I thought the VP2 was top of the line for Davis, no?
Re: Fall 2016
« Reply #220 on: November 27, 2016, 08:27:29 PM »
This is the lone function of the VP2 it doesn't have that the Vue console does, hence why I bought one a year ago.
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #221 on: November 27, 2016, 08:29:45 PM »
Ah ha! Another reason for a VP3!!
Re: Fall 2016
« Reply #222 on: November 27, 2016, 08:36:41 PM »
I realize we're getting OT, but my entire reason for a PWS is to see what's going on outside. I highly doubt a VP3 will be superior to what I have now.
Re: Fall 2016
« Reply #223 on: November 27, 2016, 08:38:48 PM »
Since you said that mine has mirrored the local NWS stations. But we haven't had any huge swings. Really interested in far off it will be. Or, maybe I won't. :-(
Re: Fall 2016
« Reply #224 on: November 27, 2016, 08:40:11 PM »
If the specs were superior you know you would buy it. :grin:
