Info regard accurate without a fan.
Sorry for my poore English here.
This is the official recomadation from the metrolocical institute in norway.
Temp sensor should not be mounted in the shade.!!
Temperature and Humidity:
Air temperature sensors should be mounted between 1.2 and 2 m above the ground, radiation sensor
humidity can be placed in the same cabin. The measurement location should be a 50 m² flat, grassy area (7m x 7m)
with large distance to the forest, buildings, water, etc. The sensor should preferably NOT be in the shade as it affects
radiation conditions and temperature errors.
Sorry this pdf is in Norwegian but use of Google translate shuld help you on the way With info. (dont thrust 100% Translation)
So if you need fan or not!!!! i supose the positioning its wrong anyway regards to official messurements, espesialy around Your house.
my davis vp2 station has 24 h fan, position at "top of house" middle of norway, coast area.
My station CWOP compare to surronding stations here:
ENAL is the official used by metrolocical insttitute in norway as
www.yr.no.
http://www.ulsteinvikweather.com/uw/wxcwopstats.php
