Author Topic: need help from the guys that tech savy  (Read 1955 times)
Offline okieman98
  • new and learning
« on: August 15, 2017, 10:24:08 PM »
ok let me explain what i want to do if possible, i know there are guys here with some freakish knowledge and mad computer skills. so i won a gopro hero 5 black this summer on vacation, i want to be able to use the time lapse mode and also view over a pc screen live  and save to a external hard drive.  anyone use one of these and know how to do it. are even if possible, i have seen weather chasers use them but not sure how its done, thanks
« Last Edit: August 15, 2017, 11:36:06 PM by okieman98 »
PWS ID HEALDTON
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
Kind regards
Bashy
Offline okieman98
  • new and learning
Re: need help from the guys that tech savy
« Reply #2 on: August 16, 2017, 03:57:52 AM »
booked marked and will try iy out thanks u
PWS ID HEALDTON
Offline okieman98
  • new and learning
« Reply #3 on: August 17, 2017, 12:51:16 AM »
is there any better instructions i could not make head are tells where to do what out of that one never could find the right area, teck dummy i guess
PWS ID HEALDTON
Offline Bashy
    • Breckland Weather
« Reply #4 on: August 17, 2017, 01:06:00 AM »
Sorry, thats what i found at the time, i dont use gopro, you could just search google, tis what i did :)
Kind regards
Bashy
Offline okieman98
  • new and learning
« Reply #5 on: August 17, 2017, 02:42:22 AM »
thanks anyway
PWS ID HEALDTON
Offline nincehelser
« Reply #6 on: August 18, 2017, 12:08:04 AM »
It's been a few years since I've done it.
The link bashy provided is correct, at least in the general concept, but if you're not familiar with VLC it might look cryptic.
You should probably check out youtube for tutorials on how to stream video from your GoPro using VLC.  I just checked and there seem to be many out there.  (I searched youtube with "VLC stream gopro").
Offline okieman98
  • new and learning
« Reply #7 on: August 18, 2017, 12:27:58 PM »
k will do
PWS ID HEALDTON
Offline Randall Kayfes
  • Weather - Photography - Astronomy - Computer Admin
    • Arizona Kaymann
« Reply #8 on: September 03, 2017, 10:33:20 AM »
Greetings,
What everybody is describing is a method of doing what GoPro's basically do not want you to do...
You are trying to grab the cache of of the live feed before GoPro kills it off.
Apples and PC's place the data in slightly different areas but the concept is the same.
The reason it is so convoluted is for some reason GoPro does not want their cameras used in stationary live mode.
Maybe some of their later camera's allow this but at least mine and older ones do not so we had to come up with these crazy workarounds...
Randall
Offline okieman98
  • new and learning
« Reply #9 on: September 04, 2017, 11:59:16 PM »
thanks u would think they would like a live stream
PWS ID HEALDTON
