Author Topic: Humidity wont go over 97%  (Read 5944 times)
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« on: June 28, 2017, 01:03:18 AM »
Hi folks,
Its been hammering down now for 18hrs straight, if i measured the rain from 8am til 8am then it would be
60mm and loads to go yet, so, how come the humidity wont go over 97% and it took hours to get there from 96%
I have a Vue down the road at 100% so Davis does go to 100% i have 2 RAF US occupied bases at 100%, oh
hold on, Marham RAF base (official UKMO Station) is only at 95%, should i shut up now?
Kind regards
Bashy
Re: Humidity wont go over 97%
« Reply #1 on: June 28, 2017, 02:24:29 AM »
Rain does not 100% humidity necessarily make. Thick fog is about the only safe bet. That being said, with your others reading 100%, even professional sensors can have difficulty pulling the 100% trigger whereas others not as much. Common issue.
Offline Bashy
    • Breckland Weather
« Reply #2 on: June 28, 2017, 02:30:32 AM »
Cheers, we did have thick fog towards the end of winter and still the same then, so it looks like mine is 97 tops
Kind regards
Bashy
« Reply #3 on: June 28, 2017, 03:25:40 AM »
If you're using this as it appears on your site, Oregon Scientific WMR928NX, then 98% is as high as your sensor will register just as is.
Offline Bashy
    • Breckland Weather
« Reply #4 on: June 28, 2017, 03:27:29 AM »
Thats the old station still in use mind but not servicing the site, thats the Davis VP2, my sites info has not been updated as yet..
« Last Edit: June 28, 2017, 04:05:26 AM by Bashy »
Kind regards
Bashy
Offline belfryboy
  • waiting for the rain.....
    • Belfryboy Blog
« Reply #5 on: June 28, 2017, 04:34:33 AM »
If your sensor is the SHT11 then @ 100% the tolerance is +/- 5%, if it's the SHT15 then you get a slightly better +/- 4%. If it's the SHT31 then the best you can hope for is +/- 2%. So all in all I'd say your sensor is within tolerance, for an electronic sensor.
Offline Bashy
    • Breckland Weather
« Reply #6 on: June 28, 2017, 04:51:31 AM »
Thanks, not got a clue whats in it, i got it in February this year
« Last Edit: June 28, 2017, 11:25:01 AM by Bashy »
Kind regards
Bashy
Offline Lucht
« Reply #7 on: June 28, 2017, 03:31:25 PM »
I have the same problem with my Vantage Vue. The ISS which has just been upgraded to the latest electronics package and yet still won't go above 97% even in fog.
« Reply #8 on: June 28, 2017, 03:52:39 PM »
The Vue only comes with the SHT11, so even more problematic hitting 100%, but can happen.
Offline Lucht
« Reply #9 on: June 28, 2017, 03:54:40 PM »
Thanks for that. At least I now know why  :-)
Offline Billyram
    • The Rapids
« Reply #10 on: June 28, 2017, 05:10:06 PM »
The most I've seen with my VP-2 is 98% but I see it regular this time of year.
Billy
Offline LeeWx
« Reply #11 on: June 28, 2017, 05:20:24 PM »
My Vue did great up until a very wet period last summer(about 5 years use). It registered 100% many times when socked in with fog. Since that period last summer it only reaches about 76% now and then drops as humidity rises to as low as 36% in heavy fog.
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #12 on: June 28, 2017, 05:26:06 PM »
I get 99% almost everytime it rains, is humid, foggy etc., but 100% Ive only seen a few times.
« Reply #13 on: June 28, 2017, 05:59:45 PM »
Sensors wear out like everything else. Time for a new one.
« Reply #14 on: June 28, 2017, 06:54:19 PM »
I just checked my maximums and since installing in November 2008 my VP2 has had:
2008 no 100% humidity
2009 5 months had 1 day at 100% and 1 month had 2 days
2010 4 months had 1 day at 100%
2011 2 months had 1 day at 100%, 2 months had 4 days, 2 months had 5 days, and December had 11 days
2012 1 month had 1 day at 100%
2013 no days at 100%
2014 1 month had 1 day at 100%
2015 1 month had 1 day at 100%
2016 2 months had 1 day at 100%
2017 1 month with 1 day at 100%
All other days had highs from 89% to 99%
Not sure why 2011 had 31 days at 100%.
Offline dendrite
« Reply #15 on: June 29, 2017, 08:05:12 AM »
That's all with the same sensor?
I've hit 100% a few times with my SHT31, but usually it maxes around 96-98% during the warm season. In the winter it maxes around 92-95%. The 98-100% tend to occur with a prolonged saturated stretch with higher dewpoints (60F+).
« Reply #16 on: June 29, 2017, 11:18:21 AM »
Yes all with the original - I haven't touched it in any way other than clean out the rain gauge occasionally and changed the battery once about 6 years ago.
Maybe time to get a replacement (WS station that is - like the guy who got a new car when the ash tray was full ;) )
Offline dalecoy
    • Lee's Summit, MO
« Reply #17 on: June 29, 2017, 11:27:39 AM »
If that is causing you great pain and discomfort, isn't that exactly what the console calibration is for?
Offline ct
« Reply #18 on: June 29, 2017, 04:57:27 PM »
Right now my SHT31 is at 100%, SHT35 is at 99.7%.  Both sensors in same FARS.
« Reply #19 on: June 29, 2017, 05:19:43 PM »
OK, sorry OT, I know you're an electronic whiz, how tough is it to get a 35 to work with our VP2's?
« Last Edit: June 29, 2017, 05:55:25 PM by CW2274 »
Offline Lucht
« Reply #20 on: June 29, 2017, 05:54:44 PM »
Got fog here right now. The Vue is saying 96%.
« Reply #21 on: June 29, 2017, 06:29:48 PM »
You might want to pull out that sensor and see if it needs a cleaning. Bugs and-other critters can block the ports that might affect the readings.
« Reply #22 on: June 29, 2017, 07:04:46 PM »
And by the way, how are you reading humidity resolution to a tenth of a percentage?
Offline ct
« Reply #23 on: June 29, 2017, 07:28:16 PM »
I'm using I2C type SHT31/35 sensors with my own controller.  The VP2 uses a different type of interface (SMBus?) which won't work with these I2C sensors.
Offline dalecoy
    • Lee's Summit, MO
« Reply #24 on: June 29, 2017, 07:39:32 PM »
Which one is correct?
