Thanks everyone. I don't see fences addressed in the PDF for ISS placement. Can I attach the ISS to a wooden fence post? Assume no tree cover or anything to block the rain.
Edit - this would be over grass and the fence is shadow box so it's not even solid.
A wood fence post is excellent. The only trouble you might have is if the post tends to shimmy in higher winds you may experience some false tips from the rain gauge (if so, a manual gauge can be used for greater accuracy). That being said, just about anything is better sited for the ISS than what you currently have.
Yep, my Wizard III barely works. The rain gauge does not work at all and I rarely get wind readings. To make matters worse, the previous homeowner did not ground anything (including the TV antenna) not to mention the Wizard is hard wired to the console inside my house. It all needs to go.
I'm searching (and searching) for a better chimney mounting solution for the anemometer and TV antenna. I've decided it has to move to the center of the back side of the chimney so I can reach it with a ladder. When I do that, I'm going to end up with only one solid mount point for the mast until it hits the ground. That stucco is not real stucco. It's only synthetic EIFS over wood and who knows how the chimney is framed out.
I saw a wrap around mounting kit but that's going to be hard to install. I would need to put a ladder on the roof to reach the front side and will end up needing my helper to also get up on the ladder instead of waiting on the ground to call 911 if I fall.
I guess I need to find a lightweight mast and eliminate the TV antenna so I can get away with only one mount point on the wood frame of the chimney. That anemometer can't be that heavy. It's just everything I do needs to be hurricane resistant.
