Interesting, care to share how you set up Interwarn to use the EMWIN data - I've tried looking at some of the files on WxMsg but not sure what I'm looking for...
Basically I am having WxMesg "manufacture" the EMWIN files for Interwarn to use. I have an alarm setup in WxMesg for all products from my local WFO (???HFO) and on the Archive tab I have the following settings:
Archive Action = FULL
Archive Type = Local
Archive Path = C:\Program Files (x86)\InterWARN\EMWINIngest\Text\$FileName$$FileExt$
Archive Option = Overwrite
Then I have Interwarn set to use "EMWIN Internet/LAN Connection" and "C:\Program Files (x86)\InterWARN\EMWINIngest\Text\" for the EMWIN Text Data directory.
This makes it so Interwarn is polling for data in that directory instead of using Interwarn's own servers.
Now, I understand this is a little odd because I'm not using WxMesg to it's full potential, and basically only using it to create an EMWIN stream for another program. But I still have alarms setup in WxMesg to process products like Tsunami watches/warnings and such that Interwarn can't really poll for on it's own.
And also, I have to realize with this setup that there is always the potential that EMWIN might change the filenames at any point which would stop Interwarn from being able to recognize some products. But I am just using this setup because I like the way the warnings are laid out on the main screen.
If at anytime Interwarn stops working or if I can no longer use it reliably, then I will just go back to having my alarms notifications setup directly in WxMesg. This is only for my own personal use, so none if this is really that critical for me. I guess I just liked Interwarn so much back in the day I don't want to let go of it!
