I was under the impression that soil and leaf go hand in hand, sommat to do with disease and gdd etc,
For me the old version is great, I only have 1 soil moisture sensor and 1 leaf sensor
Therfore a separate block just for that seems overkill
And does not look right with just that sensor. If you have a whole array of soil temp and moisture, then I spose this new soil block will be ok. But for me, deffo not,
Am I right in thinking that cause i will stay with the older block, it will mean I cannot update the template anymore? If that's the case can you not make it backward compatible?
