OK, now that everyone, that is getting one, has received there barometer. Some having it a bit longer than others, when you feel comfortable what say you as to what you think about it.
Size, face, response to change, pros, cons. What would you like to see changed? What do you really like about it?
Accuracy??
I have several points so far.
So far very happy.
Size, I love it, I can see it across the room.
Right now I will let others speak, but I do have something to comment about the face, see if you see the same thing.
Response to change, quite quick, you can see it moving.
As I have previously noted, I would like to see the location pointer a bit longer???
Accuracy as to now has been spot on -- with one of the four airport stations around me. This is the only thing I am comparing it to at this time. See the results in the new barometer for sale post. Depends where the front is coming from and what time you read the barometer. This could drive you nuts if you only have one point to check it to.
More later,
Bill.>>>>>>>>>>>>>>>>
