Author Topic: Midwest mesonet map  (Read 430 times)
Offline txweather.org
    • Texas Weather
Midwest mesonet map
« on: May 25, 2019, 07:44:55 PM »
Out of nowhere with no changes, It stop working  :shock:
https://www.txweather.org/wxmesonetmap.php
Only addition made to my site was the new WU-History Settings and page.
Any ideas?
Re: Midwest mesonet map
« Reply #1 on: May 25, 2019, 07:54:37 PM »
The reason the map is empty is because the mesonet-map-json.php script is getting a 500-Server Error instead of returning data.
no data..no map.
Looking at https://www.txweather.org/mesonet-map-check-versions.php shows that you are missing:
mesonet-map-lang-en.txt
and all the other mesonet-map-lang-*.txt files .. put them back on your site and it will likely work again.
Those files contain constant definitions that are used throughout the script set.. at a minimum, the -en file has to be there to work.
    • Texas Weather
« Reply #2 on: May 25, 2019, 07:56:19 PM »
no data..no map.
oooopppsss!!! Well burn on me. Thanks Ken. I did took them out, Cant remember why but I know I did.
« Reply #3 on: May 25, 2019, 07:56:24 PM »
My area is working http://www.komokaweather.com/komokaweather-ca/wxmesonetmap.php
and if I then go to Mid-Western it also works http://midwesternweather.net/
