ProgressThanks for all the wonderful help so far folks. Given my enjoyment of building things and that I need to use two different locations in my yard, I think I'm going to end up piecemealing a system together. Here's a component list I'm considering, I wouldn't mind hearing from anyone who's had good/bad experiences with integrating them, alternate suggestions, or knows a better place to buy than the prices/links given. Also any other interesting sensor ideas would be welcome.
General Design ThinkingI will build a Stevenson screen for the temp/humidity/pressure sensors and likely mount the rain gauge to the top of it. That whole assembly would then go on a 6-7' post buried with concrete in the most open part of the yard. Similar to the one at the bottom of this post. The anemometer would go on the roof of the house on a pole mounted via a re-used dish mount, up above the roof line (trying for the recommended 33 feet if possible).
The items inside the Stevenson screen box would all be read via a single power over ethernet powered arduino, fed from a buried pvc jacketed cable from the house. The anemometer cable could go straight through an existing soffit hole into the attic into another PoE arduino (or it might actually reach a Raspberry Pi inside my network closet).
The data would all be fed to an existing PostgreSQL database I have which feeds a Grafana UI which already has several other sensors and other bits of data from other devices around the house. I would also likely try to share the data with wunderground and whichever other major sharing sites there are.
More Questions!A few more questions that popped up while thinking this through:
- Thoughts on required size of the Stevenson screen?
- Would there be any issues attaching some makeshift bird spikes to the outside of the rain gauge?
- Would anyone forsee issues painting the outside of the rain gauge white (purely for WAF)?
- Would plants around the base of the post affect anything?
- How the heck do you put the anemometer 33 feet in the air and still get it pointed the right direction to start?
Do folks just kinda eyeball it and turn the pole at the base? - Is there any advantage to mounting the lightning sensor up high with the anemometer? Or just keep it in the Stevenson screen box with the other sensors? I assume it could still do its thing from inside an IP67 box?
- What other weather sharing sites do folks use?
- Does mounting a 33' metal pole on my house make it more prone to lightning strikes?
Here's the sample I googled which is similar to what I'm envisioning:
