Dear All,
This is a bit of a bizarre problem and I wonder if anybody else has experienced it (and hopefully found a solution).
I have been running my WMR968 for many years via a serial cable linked to an XP box running Virtual Weather Station with no problems. I have recently changed the computer to a Windows 7 64bit laptop that acts as my home server. VWS installed fine and I copied my data from the old machine to the new. As the new laptop does not have a serial port I bought (from eBay - I'm in the UK) a serial to USB cable and got the drivers installed and that seems to be working fine.
The problem is that the communication between the WMR968 and VWS only works when I touch the screen of the weather station. So when VWS loads it cannot communicate with the base station or any sensors until I touch the screen of the base station - then it gets a connection and reads the data correctly, once. It doesn't update until I touch the screen of the base station again and then sends another signal and updates VWS. This is obviously not ideal!
I have played around with all the COM port settings and unistalled and reinstalled the driver for the serial to USB cable several times. The cable obviously works as does the weather station but why doesn't it send the data automatically like it used to on my old XP box? There is definitely mains power getting to the base unit as the screen illuminates when I touch it. I have also disabled all the various sleep options in Windows to keep the laptop awake.
This is very frustrating... I'm thinking that my options are:
1) get a new base station with a USB port (which one would work with my existing sensors? - I've just got the standard sensors)
2) get a whole new weather station
3) get a new data cable
4) reinstall VWS
5) reinstall Windows
6) revert to my old XP box (although this was actually an exercise in trying to save electricity by running a new eco-friendly laptop instead of an old desktop machine)
Any help or advice would be greatly received. My feeling is this is a cable or cable driver related problem, the driver is PL2303_Prolific_DriverInstaller_v130.zip the latest (claims to work with Windows7 64) driver from Prolific.
Thanks for taking the time to read this.
Matt
