Author Topic: Question on Anemometer Remote Kit  (Read 1412 times)
Offline azchrisf
« on: September 22, 2017, 11:25:59 AM »
I installed the remote Anemometer yesterday to get better wind readings off my chimney. Works great.
The device looks like a self-contained ISS module.
It has ports for all the sensors, so my question is, could this be used to remote RF the other sensors, like UV & Solar, or is it designed only for the Anemometer?
Also doing Soil and Leaf 4x
My setup:
Re: Question on Anemometer Remote Kit
« Reply #1 on: September 22, 2017, 11:56:03 AM »
Yes, it's identical to the ISS SIM board. No, it can't be used to remote sensors other than the anemometer (unless you have an Envoy8X or Meteobridge Pro Red unit).
Offline mcrossley
    • Wilmslow Astro
« Reply #2 on: September 22, 2017, 12:01:14 PM »
Offline JudinNorman
« Reply #3 on: September 22, 2017, 01:00:06 PM »
Mine works just fine as a Temperature/Humidity Station with a regular VP2 console,  so it can be used for more sensors than anemometer.
    • Weatherelement Moline IL
« Reply #4 on: September 22, 2017, 01:11:32 PM »
To clarify... Except for the leaf wetness/soil moisture SIM, all the other station use the same ISS-style SIM board. When sending to a VP2 console, the station type in the console determines what will be received from that particular station. You can even configure a complete ISS as a temp/hum station in the console. (I've done it.)
So, sure, you can use a temp/hum station and plug an anemometer into it as well. BUT, a given console will only be able to receive it as either a temp/hum station OR an anemometer station, but not both. (or maybe as the only ISS but without a rain gauge).
Now that I've clarified, I'll muddy it up again. With 2 consoles, that hypothetical temp/hum/anny station could be received as a temp/hum station on one console, and an anny on the other. :)
« Reply #5 on: September 22, 2017, 01:12:09 PM »
Yes, you're quite right - temp/hum is the only exception, other than using a different type of receiver from a standard console (in which I include the standard Envoy) or Mark's workaround.
Edit: And of course as a supplementary temp sensor received on a standard console you only get the 1°F resolution rather than the 0.1°F of the primary temp sensors.
« Last Edit: September 22, 2017, 01:40:05 PM by johnd »
Offline Old Tele man
  • Singing in the rain...
« Reply #6 on: September 22, 2017, 02:41:31 PM »
Which is why I opted to go with a supplementary Envoy8X in addition to my original VP2 system.
« Last Edit: September 22, 2017, 02:43:50 PM by Old Tele man »
