Hi and welcome to WXForum.net!
For the Davis VP2 Plus stations with UV and Solar, the 6163 has a 24-hr Fan Aspirated Radiation Shield (FARS) for the temperature/humidity sensors, while the 6162 has the standard passive radiation shield. The FARS can yield more accurate temperature readings in direct sun than the standard shield due to it's intake of ambient air by the solar-powered fan. It will be somewhat faster to react to changes too. The 6152 is the VP2 without UV/Solar and a standard radiation shield. If you want UV and Solar, it's better (and cheaper) to get them built in with your initial purchase than to add them on later. If your wallet can stand it, the 6163 (top of the line) is the way to go.
For weather software, you'll need to order the 6510SER (WeatherLink+datalogger serial format) with your system. Even if you don't end up using WeatherLink, you need the datalogger to connect the VP console to your PC. Think of it as buying the datalogger that just happens to have some weather software with it.. the datalogger is essential, WeatherLink is not.
Check out the
Reviews section on this forum for a great set of writeups about the popular weather software, then you can pick the one that seems most comfortable for you. Many of us use
VirtualVP so we can run more than one weather station software and choose the features from each package we like.
I run WeatherLink, Weather-Display and VWS concurrently using VirtualVP.
For siting your sensors, the best guide is the
CWOP station siting guide -- 32' is the 'best' elevation for the anemometer and wind-vane. 5' for the temperature/humidity sensor and <3' for the rain gauge. With the Davis ISS, locating it at 5' and a clear 'rain view' at 30 degrees elevation all around provides the best results.
For your website, I'd recommend you get a subscription to a real hosting company that offers PHP scripting too. There are multiple choices ranging from 10$/year to $10/month. A lot of our members use
e-rice and
icdsoft for hosting. I'm using
1and1 (Business Linux). You can even start small and try your website wings with the free hosting account that usually comes with your DSL/Cable internet provider -- you won't be able to run PHP on it, but a multi-page website design is very feasible using HTML and JavaScript only. If you pick a hoster with PHP, there are a LOT of free PHP scripts available to enhance your weather website.
I'll let others (with better knowledge) talk about the cameras.
Hope this helps,
Best regards,
Ken
